Old 04-26-2013, 10:41 AM   #1
Raceseng
Raceseng's Avatar
Raceseng | Billet Aluminum Caster Camber Plates
Just wanted to give you guys a heads up as to what is going on inside Raceseng. We are developing a true independent caster and camber adjustment plate. These plates will mount under the strut tower, have plenty of caster/camber adjustment and minimum stack height! The key to our design is to make the caster and camber adjustment independent of each other. Below are some shots of our product design, development and prototyping in process!
Raceseng is offline   Reply With Quote
Old 04-26-2013, 10:44 AM   #2
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
Scott
naikaidriver is offline   Reply With Quote
Old 04-26-2013, 10:46 AM   #3
EarlQHan
Drives: Subarus
Very nice, it's about time these things hit the market. What dampers do you planning on making them compatible for?
EarlQHan is offline   Reply With Quote
Old 04-26-2013, 11:08 AM   #4
naikaidriver
Excellent question!
If these will be compatible with the Koni's, you will most certainly have at least one customer!
Scott
Old 04-26-2013, 11:18 AM   #5
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
beautiful.
SloS14 is offline   Reply With Quote
Old 04-26-2013, 02:02 PM   #6
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Damn that's purdy! Love the hardware as well.
How do these adjust caster? I can't tell just from the mounting holes, but is it just that the camber slot is off-axis so you get more caster at the same time, or is there a way to turn it that I'm not seeing?
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 04-26-2013, 02:07 PM   #7
EarlQHan
Drives: Subarus
The camber plate works like normal, but if you see where it mounts to the strut tower it's slotted vertically to adjust caster independently.
Old 04-26-2013, 02:16 PM   #8
Vten
Drives: Too heavy
I just bought a set of "temporary coilover" , ideally I want to go with KW v3, and hopefully this will complete the set !
Keep us updated !
Vten is offline   Reply With Quote
Old 04-26-2013, 02:16 PM   #9
2point0
2point0's Avatar
Duh! Totally missed that. Thanks.
Old 04-26-2013, 02:26 PM   #10
THEmailman
Drives: Raven 6MT
Seconded. What would these work on?
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
THEmailman is offline   Reply With Quote
Old 04-26-2013, 06:54 PM   #11
simpleisbest
Senior Citizen
Drives: Scion FR-S
Will ride height be effected?
simpleisbest is offline   Reply With Quote
Old 04-26-2013, 07:30 PM   #12
eckoflyte
Drives: Toyota 86 GTS
If compatible with ohlins I'd be in. What's the projected pricing on these?
eckoflyte is offline   Reply With Quote
Old 04-26-2013, 07:32 PM   #13
eckoflyte
What sort of ball bearing is being used?
Old 04-26-2013, 07:36 PM   #14
johnb831
johnb831's Avatar
Drives: SWP 2013 Subaru BRZ Limited
Very Nice!!!
johnb831 is offline   Reply With Quote
billet, billet aluminum, caster adjustment, caster camber plate, raceseng
Tein Flex Z Coilovers Evasive Motorsports Brakes, Suspension, Chassis 54 07-16-2017 01:21 AM
Raceseng | Billet Aluminum Engine Pulleys Raceseng Engine, Exhaust, Transmission 174 07-24-2014 12:24 AM
Raceseng | Lightweight Billet Aluminum Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 13 08-27-2013 01:48 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
SRP Billet Aluminum Door Sills pedalpusher Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2012 06:44 PM
