Old 08-12-2021, 01:13 AM   #1
RNG
Drives: 2013
Angle Set-back
Went to a professional workshop to have my frame checked. Got some negative in the rear camber and set-back at front. The shop said that everything is fine and there are because of bad infrastructure. BTW my area is filled with bad roads and pot holes. Any idea how can I fix this or should I just leave it without a worry?
RNG is offline   Reply With Quote
Old 08-12-2021, 02:23 AM   #2
Turdinator
Señor Member
Turdinator's Avatar
Honestly from what I've seen of our cars this is all within spec and may well have left the factory that way. If you want some better performance you could get some parts to dial in more camber but that is a preference thing rather than a necessity.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
soundman98 (08-12-2021)
Old 08-12-2021, 04:55 AM   #3
RNG
Drives: 2013
I am just hoping they do not indicate any sort of frame damage.
Old 08-12-2021, 07:34 PM   #4
Turdinator
Señor Member
Turdinator's Avatar
Our cars are surprisingly tough, if nothing is clunking and it drives well i wouldn't worry.
1974 TA22 Celica
2013 86 GT
Old 08-12-2021, 11:19 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
2 degrees isn't frame damage.
2 degrees is someone having a bad day on the assembly line. or poor alignment jig setup...
Old 08-13-2021, 03:13 AM   #6
strat61caster
strat61caster's Avatar
I don't see two degrees on any of those measurements...
ineedyourdiddly
Old 08-13-2021, 10:12 AM   #7
RNG
Drives: 2013
There aren't, I was worried about the front set-back in the first picture
Old 08-13-2021, 10:12 AM   #8
RNG
Drives: 2013
hahaha one of my friend said something similar
Old 08-13-2021, 10:34 AM   #9
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Angle Set-back
That’s 5 minutes! That’s nothing! 0.08 degrees!
Your chassis is very very straight. The corner-to-corner measurements are only off by 1mm! 3176 vs 3177
Time to stop worrying and drive the thing!
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
RNG (08-13-2021), soundman98 (08-13-2021)
Old 08-13-2021, 11:44 AM   #10
RNG
Drives: 2013
Already on it! Thanks a lot
Old 10-05-2021, 11:34 PM   #11
RNG
Drives: 2013
A friend of mine said usually there might be a value little bit higher than there is, in this case the corner to corner measurements by 1mm. He said it's a systematic error, how valid is this information?
PBM Angle kit impressions FutureFT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 11-10-2021 12:20 PM
vvt angle difference alchemis Software Tuning 2 06-12-2019 06:52 AM
VVT Angle and throttle % (OFT) nickw14 Software Tuning 7 03-22-2015 03:59 PM
Traklite Angle Jmonty Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-11-2014 12:30 AM
Best angle of the BRZ jduffy BRZ First-Gen (2012+) — General Topics 49 02-03-2013 03:06 PM
