Old 08-26-2016, 06:18 PM   #1
FutureFT86
FutureFT86's Avatar
Drives: 13 Scion FR-S
PBM Angle kit impressions
Hi guys,
Just installed my PBM angle kit and I'm having a few concerns that I hope others who have the kit can chime on on:
My steering is now much heavier than before. From a standstill, I can turn the steering wheel about one full turn and a half until it jams up. Then I have to actually move the car forward and turn the steering wheel to see the full angle of the wheels. Otherwise it's impossible to turn the steering wheel all the way to Max angle from a stand still. Is this normal? Should I be able to turn to Max angle when not moving and the car is on?
Also, when taking a turn which I have to turn my steering wheel about 90degrees from straight position my traction control light starts flashing and what sounds like a grinding noise comes from the front of the car. Nothing is rubbing. It sounds like the car is actually trying to prevent me from turning. If I keep it at that angle the traction control light will continue to flash and eventually then the abs light will also come one and stay on. I would have to turn the car off and then on for them to disappear. Now nothing is rubbing, I checked. Everything has clearance and all no lines are pinched or being pulled.
The car was aligned right after installation. They even charged extra because it's not a normal car.
Does anyone here have any thoughts? If anyone else is running the kit have you run into the same problems?
Thanks.
Check out my build: Instagram @kawallito
FutureFT86 is offline   Reply With Quote
Old 08-26-2016, 06:32 PM   #2
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Repeat your experiment with the traction control turned completely off.
I like the design of that kit, but with it you've changed the steering ratio. I'm not sure how happy the traction control will be about that. The wheel speeds at a given steering angle will not match what the T/C computer expects.
The noise is the ABS. This fires up when the traction control grabs the brakes for you.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
FutureFT86 (08-27-2016)
Old 08-28-2016, 01:28 PM   #3
Allan13
Allan13's Avatar
Drives: 2013 Subaru BRZ
What you are experiencing is normal I guess because I too have the PBM angle kit. No regrets to the kit though, best mod ever and makes difference night and day drifting.
Also whenever I drive, I always turn my t/c off. Now its a habit.
PBM angle kit, PBM coilovers, PBM RLCA, Tomei 2way diff, Hydraulic Ebrake, Bride Seat, Schorth harness.
Allan13 is offline   Reply With Quote
The Following User Says Thank You to Allan13 For This Useful Post:
FutureFT86 (08-30-2016)
Old 08-29-2016, 01:13 PM   #4
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
I've been hesitant to buy it because of this... You make the steering "quicker", so the position of the steering wheel in relation to the actual steering angle is different. That must not play well with VSC/TRAC, so i guess you lose those functionalities, which I don't want to lose for my daily.
But I don't know that for sure, just assumed by analyzing how it works. Hopefully someone can give some more insight
tato.valverde is offline   Reply With Quote
The Following User Says Thank You to tato.valverde For This Useful Post:
Old 08-31-2016, 07:56 PM   #5
FutureFT86
FutureFT86's Avatar
You're right, the noise is the abs engaging when I'm turning. If I turn off the traction control the problem goes away.
I've been advised that the traction control is activating when I turn because since I'm wider and the steering is much quicker in the front the ecu is detecting the front and rear wheels at different speeds and trying to correct by applying the rear brakes.
The Following User Says Thank You to FutureFT86 For This Useful Post:
Spartarus (08-31-2016)
Old 08-31-2016, 09:40 PM   #6
Spartarus
...Just add nauseum
Spartarus's Avatar
That is all correct.
the basic VSC / TRAC will be basically unusable beyond small steering angles.
You will have reduced steering leverage, and a heavier wheel.
All those poor drivers pre-2004 drivers.. How did they ever live without the traction and brake nannies? It's a miracle they're not all dead. /sarcasm.
In all seriousness, it's just part of the educated decision about an upgrade. Hope this is helpful.
Yes.
Try driving the car in "VSC sport" and see if the problem stays gone. That mode raises the intervention threshold for the computer, but you keep the basic stability and traction control functionality. It just lets you get a little loose before it intervenes. If that works, then you can run the kit with the nannies still working, and everybody goes home happy.
-Spartarus
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
FutureFT86 (09-01-2016), tato.valverde (09-02-2016)
Old 09-01-2016, 03:14 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
If VSC helps, IIRC there were some aftermarket thingies to set it permanently on launch.
The Following User Says Thank You to churchx For This Useful Post:
Old 09-01-2016, 01:04 PM   #8
FutureFT86
FutureFT86's Avatar
@Spartarus thanks for the advice! ABS stillI kicks in with sport mode. Even though, I have no problems with running no traction control. I was just wondering if this is all normal. Looks like it is and I'm super happy with the kit. Steering response is insane now! So quick! By far one of my favourite upgrades!
Old 09-02-2016, 12:47 PM   #9
tato.valverde
Haha my previous (and still owned) car is a '93 Mazda MX6 with no traction control, stability control, or even airbags. But hell, now that you have those things, why not keep them?
TBH the only part that's a deal breaker for me is the ABS, and that remains functional, so i'm still debating if i should jump on it and keep on living the reckless 90's life
For now I'm gonna try the Megan inner tie rods and see if I really need the angle kit yet. I'm nowhere close to being pro yet
Old 09-02-2016, 02:12 PM   #10
FutureFT86
FutureFT86's Avatar
I gotta vouch for this kit. It's really awesome. Had my first drift session yesterday and it makes a world of difference! This should have been my first upgrade of the season instead of the supercharger!
Old 09-22-2021, 09:36 AM   #11
raspec
raspec's Avatar
Drives: 2017 Subaru BRZ
why is it called PBM when its from Parts Shop Max?
raspec is offline   Reply With Quote
Old 09-22-2021, 03:42 PM   #12
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Parts
By
Max
Thank you for necroing a 5 year old thread.
Old 09-22-2021, 08:45 PM   #13
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by x808drifter View Post
Parts
By
Max
You googled that for him, didn't you?
Old 09-23-2021, 06:00 AM   #14
x808drifter
LMGTFY
Actually, no.
Knew that from years ago when the company was still based out of Japan.
The Following User Says Thank You to x808drifter For This Useful Post:
Ultramaroon (09-23-2021)
VVT Angle and throttle % (OFT) nickw14 Software Tuning 7 03-22-2015 03:59 PM
Traklite Angle Jmonty Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-11-2014 12:30 AM
Best angle of the BRZ jduffy BRZ First-Gen (2012+) — General Topics 49 02-03-2013 03:06 PM
Approach Angle at Various Heights StuAU Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 11-14-2012 03:28 PM
Right-angle iPhone cable? Sovran Electronics | Audio | NAV | Infotainment 6 09-09-2012 10:31 AM
