Old 06-12-2019, 04:30 AM   #1
alchemis
Drives: JDM Toyota 86 GT limited
vvt angle difference
Hi guys,
i'm facing some minor issue here.
basically i'm on HKS turbo kit.
they are on EL headers and the engine sound supposed to be stable and not the UEL type.
recently my engine developed UEL exhaust note around 2000rpm to 3000 rpm.
only on 10 to 20% throttle. it gradually developed this issue, it's not related to any sort of tuning as i am using HKS flash editor and it's professionally tuned. no funny noise for half a year. then this
some say it's possible where the left bank and the right bank VVT engaging angle is having some mismatch. is there a way to calibrate it ? it's a little annoying
the engine is tested to be healthy pulling 310 RWHP from stock HKS setup.
alchemis is offline   Reply With Quote
Old 06-12-2019, 05:35 AM   #2
JIM THEO
Drives: BRZ 2018
Originally Posted by alchemis View Post
Hi guys,
There is always some angle difference between left and right VVT mainly at mid-high rpms or where you ask more timing than what is possible from your setup, oil thickness and quality plays also a role on this as VVT is mechanicaly controlled from oil flow!
JIM THEO is offline   Reply With Quote
Old 06-12-2019, 06:52 AM   #3
steve99
You ill need a logging eevoce like ecutek brzedit or techstream to log emgone parameters
Such as vvt commamded and actual positions afr knock misfire counts and more
Square cut or angle cut exhaust tips...Is there a difference? Bodalenko Engine, Exhaust, Transmission 1 12-11-2018 08:23 PM
Pinion angle twag4 Engine, Exhaust, Transmission 19 07-27-2018 01:52 AM
VVT Angle and throttle % (OFT) nickw14 Software Tuning 7 03-22-2015 03:59 PM
Best angle of the BRZ jduffy BRZ First-Gen (2012+) — General Topics 49 02-03-2013 03:06 PM
