Old 08-02-2021, 06:50 PM   #1
jrhudson
Drives: 2016 scion frs
Dowel/locating pin. Camshaft sub assembly
So 1 of the 2 locating/dowel pin fell out of my camshaft sub assembly. The pin is too small for the bolt to go through. Im trying to look for the part number for it.
But i think id have to purchase the whole cam carrier assembly. I checked and the pins on the cam caps are the same size. If anyone have an extra cam cap with a dowel ill buy it. Rather not spend $150 for a pin.
jrhudson is offline   Reply With Quote
Old 08-02-2021, 07:37 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'll dig through my parts tonight and see what I have. I still have my whole scrap motor in my recycle bin and all the fasteners and dowels I saved off of it are around the shop somewhere in a plastic sorted container.
Old 08-02-2021, 08:01 PM   #3
jrhudson
Maybe I'm unlucky, but the bolt that was stuck in the pin is now ruined. I called a 4 local dealerships and fastest it'll get to me is 2 days from now. so build will stall cause of that and now this pin deal.
i appreciate it. i really do.
thanks for saving me for like the 2nd or 3rd time now. lol
Old 08-02-2021, 08:47 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Buy a lottery ticket. I found 4 of them. PM me your address I’ll ship them to you tomorrow.
Old 08-02-2021, 09:09 PM   #5
jrhudson
i sent the address.
You're the best dude. how much you want for it?
Old 08-02-2021, 09:26 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
i sent the address.
Don't worry about it. I am sure from this experience you will pass on what you learned to others. These were just stuck to the cam carriers in my recycle bin to go to scrap anyway.
Old 08-02-2021, 09:42 PM   #7
jrhudson
Definitely.
I havent replied in that thread about the shims but yes, i finally understand how to adjust the valve clearances in our FA20 motors.
I intend to update that one since researching it was a little harder to understand. Likewise, I'll update in layman's terms, meaning pictures, lol.
edit: its not a guide! But just some tips that are simplified. I have valve clearances where i want and motor is timed now. Below is the link for the valve clearance info.
https://www.ft86club.com/forums/showthread.php?t=146319
Old 08-03-2021, 01:47 AM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
Too cool.
WTB: Camshaft Timing Oil Control Valve Assembly Connector driftking96 Want-To-Buy Requests 8 05-18-2022 07:02 PM
OEM Engine Parts (HPFP, camshaft assembly, ECU, Injectors, more) ndreim Engine, Exhaust, Bolt-Ons 3 09-13-2017 09:11 PM
OEM Engine Parts (HPFP, camshaft assembly, ECU, Injectors, more) ndreim Canada Classifieds 0 07-03-2017 07:53 PM
Camshaft timing oil control valve assembly smellslikecurry Want-To-Buy Requests 11 04-12-2017 04:36 PM
Camshaft Timing Oil Control Assembly smellslikecurry Engine, Exhaust, Transmission 0 12-21-2014 12:10 AM
