Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Members Classifieds > Want-To-Buy Requests
Old 01-18-2016, 02:18 PM   #1
driftking96
Drives: 2014 Scion FR-S, 1998 Honda Accord
Question WTB: Camshaft Timing Oil Control Valve Assembly Connector
Hello,
I am looking to purchase a Camshaft Timing Oil Control Valve Assembly Connector, since my connector is stuck in the assembly and the wire has broken off. I'm looking for Bank 1 intake and Bank 1 exhaust connectors. I have attached pictures for your reference and convenience. And FYI I'm located in Ontario, Canada. Thanks.
driftking96 is offline   Reply With Quote
Old 01-18-2016, 02:24 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I would just go to the dealer or search for guys with blown engines.
good luck finding one though
Old 01-18-2016, 03:26 PM   #3
seant2h
Drives: 2013 BRZ 6MT LTD
Originally Posted by driftking96 View Post
Hello,
I am looking to purchase a Camshaft Timing Oil Control Valve Assembly Connector, since my connector is stuck in the assembly and the wire has broken off. I'm looking for Bank 1 intake and Bank 1 exhaust connectors. I have attached pictures for your reference and convenience. And FYI I'm located in Oshawa, Ontario, Canada. Thanks.
PM'd
seant2h is offline   Reply With Quote
Old 01-29-2016, 09:07 PM   #4
driftking96
Bump
Old 01-30-2016, 12:48 AM   #5
sokol
Drives: 2014 fr-s
i have them pm me
sokol is offline   Reply With Quote
Old 01-30-2016, 10:03 AM   #6
P3tras
Drives: Subaru BRZ '13 WRB
Friendly advice. Same thing happened to me, I was able to disconnect it. Use screw-driver to pry tab holds both connectors together and you should be able to pull it out. Some swearing, brute force and it should come out. Much easier and better than cutting off connector and re-soldering it.
P3tras is offline   Reply With Quote
Old 02-15-2016, 12:02 AM   #7
driftking96
Bought OEM from dealer for $90 CAD after taxes. Thanks for all the help guys.
Old 03-30-2022, 05:34 PM   #8
PostBRZtranny
You have a part number for the connector? I need a new one as well just called my local Subaru dealer inquiring about it but they said they sell it as a whole new harness not just the connector and quoted me at $320
PostBRZtranny is offline   Reply With Quote
Old 05-18-2022, 07:02 PM   #9
MicheleAbbate
MicheleAbbate's Avatar
Drives: Grr Racing FRS & BRZ
Send a message via AIM to MicheleAbbate
You still need one?
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
MicheleAbbate is offline   Reply With Quote
assembly, camshaft, connector, engine
Camshaft timing oil control valve assembly smellslikecurry Want-To-Buy Requests 11 04-12-2017 04:36 PM
Camshaft timing oil control valve assembly - P0013 smellslikecurry Issues | Warranty | Recalls / TSB 8 11-02-2016 09:53 AM
Oil Leak at Camshaft Timing Controler Cal3000 Issues | Warranty | Recalls / TSB 17 10-03-2015 11:38 AM
Camshaft Timing Oil Control Assembly smellslikecurry Engine, Exhaust, Transmission 0 12-21-2014 12:10 AM
Valve Timing/Computer miss paula Issues | Warranty | Recalls / TSB 3 09-20-2012 03:27 PM
