Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > CANADA > Canada Classifieds
Old 07-03-2017, 07:53 PM   #1
ndreim
ndreim's Avatar
Drives: 2014 wrb brz 6MT
OEM Engine Parts (HPFP, camshaft assembly, ECU, Injectors, more)
Selling left over parts:
High pressure fuel pump, doesn't chirp, however due to the nature of these, it may start to $120
Driver's side camshaft assembly $100
Injector Control ECU (from a 2013 USDM frs, I'm not sure on the compatibility issues) $90
Miscellaneous nuts and bolts, ideal for a rebuild - save some headaches . $40
Fuel lines and some other (coolant line I think?) $20
OEM Fuel Injectors . $75
FRS Grille $40
Underbody panels $90
Also have the stock intake tube + resonator if anybody needs that $15
porsche exhaust tips +10 horsepower
ndreim is offline   Reply With Quote
OEM Engine Parts (HPFP, camshaft assembly, ECU, Injectors, more) ndreim Engine, Exhaust, Bolt-Ons 3 09-13-2017 09:11 PM
Camshaft timing oil control valve assembly smellslikecurry Want-To-Buy Requests 11 04-12-2017 04:36 PM
OEM: CHIRP-free high pressure fuel pump, camshaft assembly, stock injectors, ecu ndreim Engine, Exhaust, Bolt-Ons 5 11-23-2016 11:36 PM
OEM camshaft assembly, pulleys, intake tube, sound generator, injectors, frs grille, ndreim Engine, Exhaust, Bolt-Ons 7 08-15-2016 08:46 PM
Camshaft Timing Oil Control Assembly smellslikecurry Engine, Exhaust, Transmission 0 12-21-2014 12:10 AM
