Drives: 2014 wrb brz 6MT
OEM Engine Parts (HPFP, camshaft assembly, ECU, Injectors, more)
Selling left over parts:
High pressure fuel pump, doesn't chirp, however due to the nature of these, it may start to $120 Driver's side camshaft assembly $100 Injector Control ECU (from a 2013 USDM frs, I'm not sure on the compatibility issues) $90 Miscellaneous nuts and bolts, ideal for a rebuild - save some headaches . $40 Fuel lines and some other (coolant line I think?) $20 OEM Fuel Injectors . $75 Willing to ship anywhere ![]() ![]() ![]()
porsche exhaust tips +10 horsepower
Cool Stuff
Drives: Cool Car
Ok me price for steel brackets to 30152
bump
bump
| Tags |
| camshaft, ecu, hpfp, injectors, oem |
| Camshaft timing oil control valve assembly | smellslikecurry | Want-To-Buy Requests | 11 | 04-12-2017 04:36 PM |
| OEM: CHIRP-free high pressure fuel pump, camshaft assembly, stock injectors, ecu | ndreim | Engine, Exhaust, Bolt-Ons | 5 | 11-23-2016 11:36 PM |
| Camshaft timing oil control valve assembly - P0013 | smellslikecurry | Issues | Warranty | Recalls / TSB | 8 | 11-02-2016 09:53 AM |
| OEM camshaft assembly, pulleys, intake tube, sound generator, injectors, frs grille, | ndreim | Engine, Exhaust, Bolt-Ons | 7 | 08-15-2016 08:46 PM |
| Camshaft Timing Oil Control Assembly | smellslikecurry | Engine, Exhaust, Transmission | 0 | 12-21-2014 12:10 AM |
