Old 07-21-2021, 12:57 PM   #1
DarkSunrise
DarkSunrise's Avatar
OFT Question re. Flashing Stock Tune
@steve99 @Wayno (or anyone else with knowledge)
Are there any issues with flashing my original tune (.ori) onto my ECU the same way I would any other OFT tune file? In other words, can I load it into one of the MODIFIED slots on my OFT and flash it that way?
Back story - I had to wipe my OFT due to a corrupt file. After the wipe, it read a pre-existing OFT tune on my car as the original. Thankfully I had saved the real original tune on my laptop and need to load it back into the ECU.
Thanks!
2022 BRZ Build
2013 FR-S Build
Old 07-21-2021, 11:28 PM   #2
DarkSunrise
Nvm got a response from Vishnu! For anyone wondering, no issues flashing to stock this way.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
zc06_kisstherain (07-22-2021)
Old 07-22-2021, 12:43 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Except unmarrying OFT to prepare it to resale to someone else in future will still put back whatever tune you had at time when re-married OFT after reset, even if you can flash stock tunes too from "modified slots". Still married to other car OFT has no use for next owner.
Old 07-22-2021, 01:48 AM   #4
DarkSunrise
Yep thanks, I realized that but I'll cross that bridge when the time comes.
2022 BRZ Build
2013 FR-S Build
Old 07-22-2021, 05:56 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
I'd rather try now, when memory still fresh, contact very same people you conversated with regarding reset, describe your issue, and arrange first flash via "modified" stock tune back, and then do another reset of OFT, so that you can marry it with right, stock, tune, which will enable problemless unmarrying/resale in distant future.
The Following User Says Thank You to churchx For This Useful Post:
DarkSunrise (07-22-2021)
Old 07-22-2021, 07:01 PM   #6
steve99
Thanks!
All ok you xan just load a stock tune into one of the tune slots and flash it
bit as mentioned oft always want to flash back the tune that it read in originally to unmarry device and if that tune was not stock it still want to flash that back
Flashing an OFT tune using a Tactrix Openport 2? Bottlespeaker Software Tuning 1 02-23-2020 11:14 AM
Help - rpm drops after flashing E85 tune. Joyriding_86 Issues | Warranty | Recalls / TSB 14 11-06-2019 02:42 PM
Lit symbols in dashboard after flashing Xero Limit tune kev0 Software Tuning 19 07-07-2019 06:05 AM
After flashing A new tune to your car John27 Software Tuning 5 06-08-2018 02:03 PM
Flashing your ECU question Blackout808 Engine, Exhaust, Transmission 3 04-05-2013 10:33 PM
