Drives: scion fr-s
After flashing A new tune to your car
is it necessary to disconnect battery to reset ecu just after loading new tune to your car ?
Drives: Subaru BRZ
No.
Drives: 17 Series Yellow BRZ
The ecu gets reset on every flash.
Drives: scion fr-s
thank you guys
Drives: brz 2017 hksv2
After every reflash just keep it for 30 seconds in IGN ON mode, then push dowb the throttle all the way slowly 2 times, then crank the engine up and leave it idle for 3 minutes without touching throttle
You re good To go then. |
#6 | |
Disconnecting the battery after the tune will only set you back. Start the car after the flash is complete, don't touch the throttle and let the car idle for 2 minutes. Then when you drive work your way through the rev range to allow the ecu to run through the new tune.
| Flashing and Intermittent CEL - HELP | MugsBRZ | Issues | Warranty | Recalls / TSB | 7 | 10-19-2016 11:56 AM |
| Yellow flashing key fob | Matty B | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 11-20-2015 07:35 AM |
| Flashing from E85 to 91 | Phantobe | Software Tuning | 18 | 02-16-2015 06:44 PM |
| Flashing cel wtf ! :/ | sweetfrs | Issues | Warranty | Recalls / TSB | 16 | 12-07-2013 02:13 AM |
| anybody else see the flashing carrot??? | poormans_LFA | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 01-18-2012 09:25 AM |
