Old 07-07-2021, 07:24 PM   #1
saltywetman
Drives: 2020 Toyota 86 GT 6M
Question re: aftermarket LSD and final drive
Do aftermarket lsd such as Cusco or the direct drop in os giken super lock affect the final drive?
saltywetman is offline   Reply With Quote
Old 07-07-2021, 07:39 PM   #2
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Originally Posted by saltywetman View Post
Do aftermarket lsd such as Cusco or the direct drop in os giken super lock affect the final drive!
Final drive is determined by the ring and pinion gears, not the differential. The ring gear bolts to the differential.
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
The Following User Says Thank You to nextcar For This Useful Post:
saltywetman (07-07-2021)
Old 07-07-2021, 10:34 PM   #3
saltywetman
Thanks! Thats what I needed to know!
Old 07-07-2021, 11:06 PM   #4
nextcar
BTW, since it seems that you are unfamiliar with the internals of the 3rd member...
Setting up the ring and pinion requires a dial indicator and grease paint. If you do not get the gear depth/engagement right you will have a very noisy unit and possibly excessive wear.
Most shops charge several hundred dollars to set up a 3rd member, and that is if you bring it to them already removed from the car. If you don't bring it in removed and drive in with a new LSD and ask them to install it, be prepared to pay $500-$1000. Rates vary greatly.
Pull out
saltywetman (07-08-2021)
Needed: drive line shop in Houston for 4.56 final drive install - good experiences? Joesurf79 Southwest 3 03-10-2017 01:21 AM
Aftermarket Final Drive Whine c8Face Engine, Exhaust, Transmission 13 05-21-2016 02:35 PM
Final drive tcroft91 Engine, Exhaust, Transmission 19 02-08-2016 12:09 PM
4.56 Final Drive Question about Acceleration jaorocks1 Engine, Exhaust, Transmission 12 01-20-2016 09:12 AM
Final Drive and speedometer question shif7i7down Engine, Exhaust, Transmission 8 05-13-2014 03:37 PM
