Old 05-14-2016, 01:06 AM   #1
c8Face
c8Face's Avatar
Drives: 2016 BRZ
Aftermarket Final Drive Whine
I purchased a 2016 BRZ with the final drive already changed. I am not sure what part/ratio, but based on my speed, rpms, tire diameter, stock gear ratios, I am fairly confident it is the Mfactory 4.67 final drive.
Does anyone have this installed?
I am experiencing a whine from the diff that is not super loud, but definitely noticeable. I've talked to a few mechanics, and some say it's normal for an aftermarket FD, while others say it's too loud.
Any input from aftermarket FD owners (especially MFactory) would be appreciated.
Thanks.
c8Face is offline   Reply With Quote
Old 05-14-2016, 01:08 AM   #2
e1_griego
e1_griego's Avatar
Drives: Many
What's the bushing situation? When do you hear the whine?
e1_griego is offline   Reply With Quote
Old 05-14-2016, 01:21 AM   #3
c8Face
c8Face's Avatar
Drives: 2016 BRZ
Factory bushings. Whine can be heard from low speeds but is loudest at speeds greater than 35 mph. I've read this is "normal" for the Mfactory semi helical cut gears but I have no comparisons to reference. A friend who has never been in my car didn't even notice the whine until I told him about it. I'm considering having a diff shop check it out.
The Following User Says Thank You to c8Face For This Useful Post:
jcw99 (05-21-2016)
Old 05-16-2016, 10:57 AM   #4
mrk1
Drives: Sterling BRZ Ltd
I have had the MF 4.44 and yes they whined, MF said this is normal, how ever this is also to be expected on even numbered gear sets.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
jcw99 (05-21-2016)
Old 05-16-2016, 11:03 AM   #5
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
I have stock final drive, with subframe bushings and diff bushings and I hear alot of whine. I guess its just added noise with the aftermarket bushings
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following User Says Thank You to nickmerronesucks For This Useful Post:
jcw99 (05-21-2016)
Old 05-16-2016, 11:36 AM   #6
stevesnj
stevesnj's Avatar
Use higher viscosity oil. like..
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
jcw99 (05-21-2016)
Old 05-16-2016, 09:44 PM   #7
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
I have the mfactory 4.67 years as well and there is Wine and cheese. this is normal for those gears and even going with Lucas higher viscosity oil make it quieter you'll still hear it.
Living the dream in a nightmare.
skye67 is offline   Reply With Quote
The Following User Says Thank You to skye67 For This Useful Post:
jcw99 (05-21-2016)
Old 05-20-2016, 12:17 AM   #8
c8Face
c8Face's Avatar
Drives: 2016 BRZ
Thanks for the input. I had it checked out by a local shop that specializes in rear ends, and they confirmed the prior FD install was not set up correctly in terms of the backlash/pinion depth. Fortunately, the dealership where I bought the car paid the bill to have it reset it correctly. The the whine is still there, but it is definitely less than before (especially on the highway).
For those interested, I also contacted MFactory regarding the diff whine. Below is their response:
"Our final drives are made with the same tooth profile in that they are semi-helical. Also, the teeth themselves are larger, made for durability, which will also make some noise. "
jcw99 (05-21-2016)
Old 05-20-2016, 12:30 AM   #9
jcw99
Drives: swp mt '14 brz premium
I have a new 4.56 Weir drive that has a slight whine to it. I notice it most in higher gears. When I let off the gas there is no whine.
jcw99 is offline   Reply With Quote
The Following User Says Thank You to jcw99 For This Useful Post:
nickmerronesucks (05-21-2016)
Old 05-20-2016, 03:46 PM   #10
c8Face
c8Face's Avatar
Drives: 2016 BRZ
I have the exact same experience. Most noticeable at highway speeds while on throttle.
jcw99 (05-20-2016)
Old 05-21-2016, 05:08 AM   #11
blackspike
blackspike's Avatar
Drives: Toyota GT86 racing red, Aero
I also have the 4.67 MFactory final drive and it whines specifically at light acceleration.
There is a extra loud resonance at 37 and at 56 miles per hour.
At the first time my local shop don`t set the gears correctly (wrong pinion depth), second time the same problem... then i drove 450 miles to another shop which is specialized on the GT86 and the 4.67 final drive.
Now my gear setup is nearly perfect (slight deep conditions for best performance) and minimal backlash for best response.
Unfortunately the gears are still whining because of the wrong setup at the beginning.
They told me it will get silence after about 10k miles - we will see.
The MFactory gears arent polished and they are cut different from oem (semi helical - it is a compromise between verry loud straight cut und silent helical), so they will also whine when the setup is correct but not that loud.
My drive pattern:
blackspike is offline   Reply With Quote
The Following 2 Users Say Thank You to blackspike For This Useful Post:
c8Face (05-21-2016), jcw99 (05-21-2016)
Old 05-21-2016, 06:17 AM   #12
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
I have the Cusco 4.556 and can't say I really hear any whine to be honest. Not sure if it helps, but the workshop I used advised to use only Castrol 85W-140 diff fluid (if it ever needs changing) and that's what they used on my install.
Could also be down to the gear set being genuine Toyota parts so may be designed to simply run quieter? - http://www.cuscousainc.com/catalogse...esult/?q=4.556
I was also given strict instructions for the run in process. No way to tell if those were followed prior to you taking delivery of the car in this case though I guess.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
The Following User Says Thank You to Mim For This Useful Post:
jcw99 (05-21-2016)
Old 05-21-2016, 06:24 AM   #13
blackspike
blackspike's Avatar
The 4.556 Cusco final drive is full helical cut like the oem final drive.
85W-140 diff fluid is a good advice, it help to reduce the whine but don't expect wonder.
The Following User Says Thank You to blackspike For This Useful Post:
jcw99 (05-21-2016)
Old 05-21-2016, 02:35 PM   #14
skye67
skye67's Avatar
The gear whine is a noted side effect of M factories gears. I would have gone with another gear set but I was made an offer I couldn't refuse on this one I have my car now. I got them cheep already installed in a diff. I don't mind the gear wine, I think it sounds kind of cool.
Final drive tcroft91 Engine, Exhaust, Transmission 19 02-08-2016 12:09 PM
Final Drive: 4.56 vs. 4.88 mcbrawr Engine, Exhaust, Transmission 43 12-26-2015 08:23 PM
WTB: 4.56 Final Drive jaorocks1 Want-To-Buy Requests 0 11-04-2015 08:36 PM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 04:11 PM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 03:51 PM
