Old 07-25-2012, 07:15 PM   #1
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
Installing the AVO Rear Reinforcement Bracket
DIY install guide - AVO Reinforcement Bracket for the Rear Stabilizer Bar Mount
The two rear mounts for the rear stabilizer bar brackets are ok - for standard rear bars - but not great. While the BRZ and FRS is still relatively new, past Subaru models with the same rear suspension setup have had issues with larger bars flexing, and sometimes breaking, the rear mounts. So we created some rear mount reinforcement brackets to keep this from happening.
This is a guide on how to install the rear mount reinforcement brackets.
1) Start by removing the large bolt from the differential mount bracket above the stabi- lizer bar mount bracket. This should be a 17mm bolt. Remove the bolt and the plate. You will not re-use the plate.
2) Fit the AVO rear stabilizer bar mount bracket to the rear differential mount with the large bolt. The bracket replaces the plate that was there fully. Loosely tighten it up, do not tighten it fully.
3) Once it’s lined up properly (between the two outer ridges of the bushing bracket), tighten these two bolts up first.
4) Now remove the two bolts holding the stabilizer bar bushing bracket down. You will not re-use these two bolts either. These should be 12mm in size.
5) Now fit the provided bolts with spacers to the stabilizer bar bushing mount bracket. Lightly tighten these up, and get the bracket lined up properly.
6) Finally, tighten the large bolt up fully, and make sure that everything is lined up properly. Loosen the bolts off and re-align if necessary.
Note: After completion and removing your tools, double check for any loose nuts or misaligned fittings.
AVOturboworld is offline   Reply With Quote
Old 07-26-2012, 06:41 AM   #2
dave14jones
Drives: etios
Good Job Mate.....
dave14jones is offline   Reply With Quote
Old 07-26-2012, 03:38 PM   #3
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 07-26-2012, 03:52 PM   #4
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Curious... torque values for all those bolts? Thanks for the walkthrough.
cobrabyte is offline   Reply With Quote
Old 07-27-2012, 07:17 AM   #5
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Nice product. It seems like it would be a great help with R-Compound tires and a beefier sway bar.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 07-28-2012, 11:20 AM   #6
jehu
Drives: JDM LN130 Toyota Hilux Surf
Looks nice and tidy. also keen to know torque specs.
Is this part for sale currently, or still in R&D?
cheers
jehu is offline   Reply With Quote
Old 07-29-2012, 11:28 PM   #7
AVOturboworld
It's currently for sale, we've already made the initial run and working on more.
Old 07-31-2012, 06:19 PM   #8
jehu
can you hyperlink me to this please? It seems my searching skill fail me. cheers
Old 07-31-2012, 07:55 PM   #9
AVOturboworld
Not your fault, seems to have fallen off the website for some reason.
Up now:
http://www.avoturboworld.com/avoshop...ace-p-175.html
Old 10-29-2012, 11:44 AM   #10
gmookher
Have these been tested with the whiteline rear crossmember bushings? the do change the orinetation of the upper plate in relation to the bar bracket bolts holes. I'd like to try a set, and report back.
gmookher is offline   Reply With Quote
Beatrush Chassis Reinforcement Group Buy Kami Speed Brakes, Suspension, Chassis 40 07-30-2012 09:39 AM
Slimline Plates Plate Bracket eleu2166 AUSTRALIA 40 07-25-2012 11:45 PM
Grimspeed Tag bracket on dgm Coastermikey BRZ First-Gen (2012+) — General Topics 19 06-25-2012 06:54 PM
AMT rear sway bar bracket adamturbo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-13-2012 11:06 AM
