Drives: 2013 Scion FRS
2017 86 Header Compatible with 2013 FRS?
Hi everybody,
I need to replace the header on my 2013 FRS due to the cat failing. I am looking at replacing it with another stock header for now. I found a stock header from a 2017 86 and am wondering if these parts are interchangeable with no issues mounting. I am sort of new to these cars, so I am sorry if this has an obvious answer. Thanks! |
#2 | |
Drives: 2017 PP BRZ
https://www.ft86club.com/forums/showthread.php?t=110818 https://www.ft86club.com/forums/showthread.php?t=111101 |
Drives: 2017 PP BRZ
Welcome to the club.
This question seems easy, but they changed the flange on the 17+ models. I reckon @humfrz or @Ultramaroon knows. |
#4 | |
Ol @Ultramaroon don't know nutten bout loud exhausts - so, Bubba tells me -
No issues. I’m using a revised 2017 manifold and it fits the same as my 2013. Sounds better too in the midrange due to the revised (more EL) layout. Bolt it on and enjoy.
2022 BRZ Build 2013 FR-S Build |
#6 | ||
not playing cards
![]() Quote:
#7 | |
100% works.
2013 Series 10 FRS #553
#9 | |
Rust bucket enthusiast
everything else fits perfectly. This just means you can't mix and match exhaust from the midpipe to the axleback, but it's fine if you swap the whole catback
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block Last edited by DarkPira7e; 05-16-2021 at 03:13 PM. |
#10 | |
#11 | |
Drives: 2017 PP BRZ
#12 |
Drives: JRSC BRZ SOLD
It fits fine, but the header flange is about 1/4" farther forward than the MY13-16. So the rest of the exhaust system will be pulled forward by that amount. Its not terrible but you will notice it during the install.
#13 |
Thanks for the replies, everybody! Great help, and looks like I will be getting the 2017 header I found for sale. Thanks again
| 2017 86 Header Compatible with 2013 FRS? | mrhood | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 05-06-2022 07:14 PM |
| Can I pass smog with a 2017+ header on my 2013? | norcalpb | Northern California | 6 | 08-23-2020 03:33 PM |
| 2014 engine compatible in 2013 car? | Meppster | Engine, Exhaust, Transmission | 3 | 09-03-2019 06:20 PM |
| Aftermarket Intakes Still Compatible with 2017? | Xeneon | Engine, Exhaust, Transmission | 7 | 04-19-2017 09:21 PM |
| Is Unichip 2013-14 compatible with 2015? | babydriver | Software Tuning | 4 | 06-03-2015 10:40 PM |
