Old 05-15-2021, 08:55 PM   #1
mrhood
Drives: 2013 Scion FRS
2017 86 Header Compatible with 2013 FRS?
Hi everybody,
I need to replace the header on my 2013 FRS due to the cat failing. I am looking at replacing it with another stock header for now. I found a stock header from a 2017 86 and am wondering if these parts are interchangeable with no issues mounting. I am sort of new to these cars, so I am sorry if this has an obvious answer.
Thanks!
mrhood is offline   Reply With Quote
Old 06-25-2021, 09:18 PM   #2
jflogerzi
jflogerzi's Avatar
No problems. They are almost exactly the same with a bit better runner desgin
2013 Series 10 FRS #553
Old 06-25-2021, 11:29 PM   #3
PulsarBeeerz
Drives: JRSC BRZ SOLD
They fit OK. The over pipe flange is maybe 1/4" forward compared to the MY13 header.
PulsarBeeerz is offline   Reply With Quote
Old 05-06-2022, 10:54 AM   #4
Compelica
Compelica's Avatar
Drives: 86 GT
Not sure what you meant... will the exhaust tips now stick further quarter inch outwards or inwards?
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 05-06-2022, 07:14 PM   #5
PulsarBeeerz
1/4" inward.
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
Compelica (05-06-2022)
HKS Legamax Premium Series Catback Exhaust - 2013-2016 FR-S/2017+ 86/2013+ BRZ burgeralert Engine, Exhaust, Bolt-Ons 2 11-15-2020 10:08 AM
Can I pass smog with a 2017+ header on my 2013? norcalpb Northern California 6 08-23-2020 03:33 PM
2014 engine compatible in 2013 car? Meppster Engine, Exhaust, Transmission 3 09-03-2019 06:20 PM
Aftermarket Intakes Still Compatible with 2017? Xeneon Engine, Exhaust, Transmission 7 04-19-2017 09:21 PM
Is Unichip 2013-14 compatible with 2015? babydriver Software Tuning 4 06-03-2015 10:40 PM
