Drives: 2017 Subaru BRZ Limited PP Pure Red
My 2017 BRZ is scheduled to arrive next month, and I'm looking at possible intake options. My questions are:
1) Since I know certain components were redesigned or have different dimensions on the 2017, will this make existing aftermarket options not compatible out-of-the-box? Looking specifically at the GrimmSpeed intake, but open to others (that don't require removing the bumper to install). 2) Along the same lines, does the slightly increased 2017 HP from refreshed factory intake mean I'm going to be getting even less benefit from an aftermarket intake? Is it even worth doing? Has anyone done dyno comparisons for the 2017? Thanks.
Drives: 2010 LGT
Drives: 2005 Toyota Camry
The only thing different on the intake is the airbox and drop-in filter element. Everything else is same and aftermarket parts (either intake tube, intake assembly, or intake system) will fit fine.
#4 | |
The thread you referenced is a general question about best intakes available "in 2017" |
#5 | |
Drives: 22RE, FA20, 4G63
I instal a injen intake and the OFT in 2017 GT, no problem at all. About spending that amount for that gain in hp I don't know, I just did it because I have that (aftermarket parts sitting around for couple of years a buy another toy). |
Drives: 2022 GR86
They should all fit fine.
I had a Grimmspeed (not 2017 specific) in my 2017 BRZ for a while. However, I went back to stock airbox and the Perrin inlet tube with a drop-in Blitz filter. My tuner recommends staying with the stock airbox, not much to gain with the various aftermarket ones (although they do give that whooshing/sucking sound when you blip throttle).
#7 | |
Blitz released a new intake kit for the kouki 86 models. The difference is the silicon coupler that connects the factory airbox to the intake tube, the kouki model uses a coupler that is approx. 3/4" longer. It may not make a difference and you might be able to get your zenki intake tube to bolt up without issues, but it's off by just enough to where aftermarket intakes need a slightly longer coupler. FYI. |
Drives: 2017 manual BRZ
http://www.ft86speedfactory.com/blit...17-brz-86.html
This is available. I'm just curious if it flows better than the already ~30% higher flowing 2017 OEM filter. |
| DIY - Aftermarket Head Unit install on 2017 BRZ | Akuma147 | DIY (Do-It-Yourself) Guides | 86 | 08-17-2021 10:38 PM |
| What aftermarket parts will fit the 2017 GT86? | luxzje86 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 02-14-2017 06:45 PM |
| Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift | ModinJapan | Southern California | 1 | 01-25-2017 12:46 AM |
| Are aftermarket intakes worth it? | wbsrazzle | Engine, Exhaust, Transmission | 100 | 05-15-2013 02:51 PM |
| Aftermarket intakes & tunes... | zooki | Engine, Exhaust, Transmission | 5 | 12-19-2012 02:18 PM |
