Old 03-30-2021, 03:03 PM   #1
Jreyes96
‘15 engine in a ‘13
My engine blew in my 2013, so I bought a 2015 from a yard. When switching I noticed the sensors are different on the 2015. I switched the plugs from the wiring harness and I’m getting an engine light with P0017 (Cam sensor) which causes the engine to lose power. Any advice?
Jreyes96 is offline   Reply With Quote
Old 03-30-2021, 03:12 PM   #2
tomm.brz
Drives: brz 2017 hksv2
use 2015 sensors, and put 2015 tune in your ecu
Old 03-31-2021, 07:43 AM   #3
Presume that the engine is appropriate for the transmission type. Not a MT to AT or vice versa unless the proper changes have all been made.
Old 03-31-2021, 07:49 AM   #4
tomm.brz
actually i don't think anymore it's so simple
he needs @steve99 opinion
Old 03-31-2021, 01:14 PM   #5
Jreyes96
Didn’t think the tune would cause power loss. I’ll look into that. Appreciate it!
Old 03-31-2021, 01:15 PM   #6
Jreyes96
Yeah they’re both AT
Old 03-31-2021, 01:17 PM   #7
Was worth mentioning.
Old 03-31-2021, 02:38 PM   #8
tomm.brz
from 2015 they started changing things in electronics
so you HAVE to use a tune that matches your engine or CELs will throw
Old 03-31-2021, 04:47 PM   #9
wparsons
wparsons's Avatar
You're thinking 2017+
For 2015/2016 the only difference is the coil pack plugs. Run the coil packs that came in the car and it'll be fine, no need for a different tune or anything else.
2017+ has different sensors and needs a 2017+ ECU, or the older sensors swapped over to the new engine, the tune alone isn't enough.
flickr
Brief engine knock/cold engine/first couple accelerations@2.8-3krpm Reyanth Issues | Warranty | Recalls / TSB 5 11-15-2020 02:32 PM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
direct injector Failure , sand in the engine and on the engine aagun Issues | Warranty | Recalls / TSB 3 05-26-2014 02:46 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
