Old 03-28-2021, 12:09 AM   #1
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
built block options
so i blew my engine today cruising on the highway. oil all over the place and none in the engine. its totally seized. so now i guess i build the block and throw the super charger on which i get monday. so what are my options? I guess IAG closed deck?
Breadman is offline   Reply With Quote
Old 03-28-2021, 08:42 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Closed deck is unnecessary, our cylinder walls are not thin like EJ motors. Stage 1 IAG is fine
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
DarkPira7e is online now   Reply With Quote
The Following User Says Thank You to DarkPira7e For This Useful Post:
Breadman (03-28-2021)
Old 03-28-2021, 08:56 AM   #3
Breadman
Breadman's Avatar
for heads and cam do you just run stock? i have a c38 showing up tomorrow and i am extremely tempted to just say fuck it and go full project car and get an RS pulley and cd009 swap. im kind of glad this happened now vs when i would be tuning it with zach
Old 03-28-2021, 10:08 AM   #4
TommyW
TommyW's Avatar
Drives: '13 Whiteout
I used the IAG S1 but stayed NA. Have the stock heads machined and if you have an oil cooler trash it and get a new one.
Old 03-28-2021, 10:17 AM   #5
Breadman
Breadman's Avatar
im good it still is in the mail. should show up monday! perfect timing
Old 03-28-2021, 10:46 AM   #6
DarkPira7e
DarkPira7e's Avatar
Yep, everything works with stock. Stock headgaskets as well
Old 03-28-2021, 11:41 AM   #7
Breadman
Breadman's Avatar
you didnt even add new springs?this could save a bunch assuming i spun a bearing and didnt have vvt shit the bed and smash everything
Old 03-28-2021, 12:41 PM   #8
DarkPira7e
DarkPira7e's Avatar
I would recommend upgrading the valve springs. I meant as far as boring them out, upgrading cams, etc
Old 03-28-2021, 12:54 PM   #9
Breadman
Breadman's Avatar
cool thanks for the info. now at least i know where to start looking. this whole situation fucking sucks. i knew i would blow my engine eventually but i figured it would be on the track after supercharging now cruising the highway NA
Old 03-28-2021, 12:56 PM   #10
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
What caused the failure?
Old 03-28-2021, 01:02 PM   #11
DarkPira7e
DarkPira7e's Avatar
Yeah it's a miserable situation no matter where it happens. Mine spun itself (for the 3rd time) on my way to work on a negative 5 degree F morning.
Make certain that you run all of your purchases choices by the tuner before making them; the last thing you want is something your tuner/builder doesn't recommend and they don't want to deal with figuring it out.
Biggest thing to be certain of is that you get a checklist of everything they're going to need- headstuds, fluids, gaskets, etc.
Old 03-28-2021, 01:13 PM   #12
Breadman
Breadman's Avatar
i havent looked but seeing how there is oil everywhere but the pan and the engine is seized i think i spun a bearing and threw a rod
Old 03-28-2021, 01:14 PM   #13
Breadman
Breadman's Avatar
yep calling csg during lunch tomorrow assuming some asshat didnt schedule a lunch meeting. also already making the sheet
Old 03-28-2021, 09:02 PM   #14
ML
ML's Avatar
Drives: 13 White MT FR-S
I would recommend Element tuning to build block or just drop the FA20
FS: FA20 Fully Built Short Block MicheleAbbate Engine, Exhaust, Bolt-Ons 24 08-28-2019 09:57 PM
FBM stage 1 built block questions Matey Engine, Exhaust, Transmission 5 03-24-2017 07:39 AM
Crawford Built Short Block texasbound972 Engine, Exhaust, Transmission 26 05-15-2015 03:39 PM
Built B18B Short Block C130NAV Miscellaneous 0 01-04-2014 12:15 PM
