Old 03-22-2021, 04:43 PM   #1
PH03N1X
PH03N1X's Avatar
Misaligned gear shifter after transmission reinstall
This weekend, I replaced my clutch and flywheel. I believe that my shifter is now misaligned. I think that the reverse gear is engaged when going into the 1st gear position, as I can't move to the 2nd gear position. How do I realign the shifter and linkage properly? HELP!
Sent from my HD1925 using Tapatalk
PH03N1X is offline   Reply With Quote
Old 03-22-2021, 04:49 PM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
well you see the lockout plate there, just adjust it so it doesn't go into reverse? lol
HKz is offline   Reply With Quote
The Following User Says Thank You to HKz For This Useful Post:
PH03N1X (03-23-2021)
Old 03-22-2021, 05:04 PM   #3
PH03N1X
PH03N1X's Avatar
It does this without the lockout plate installed.
Old 03-22-2021, 05:09 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
Totaled
See link to manuals in my sig line.
Old 03-22-2021, 05:19 PM   #5
PH03N1X
PH03N1X's Avatar
Totaled
Totaled? What do you mean?
Old 03-22-2021, 05:26 PM   #6
PH03N1X
PH03N1X's Avatar
I just remembered that I didn't install one of the two MTech shifter springs. The one under the big nut is still stock.
Old 03-22-2021, 05:35 PM   #7
PH03N1X
PH03N1X's Avatar
Totaled
I also can't see your sign in Tapatalk. I've got the service manual already, though
Old 03-22-2021, 05:53 PM   #8
Ultramaroon
not playing cards
All the answers to your questions are there. See how wide the holes are in the top plate? Critical and relatively easy adjustment.
PH03N1X (03-22-2021)
Old 03-22-2021, 06:34 PM   #9
PH03N1X
PH03N1X's Avatar
I think I was just over thinking it, worried I had messed up somewhere. There's just such a small gap between reverse and 3-4. Might have just got it. Thanks to everyone who replied!
The Following 3 Users Say Thank You to PH03N1X For This Useful Post:
theneptune86 (03-22-2021), Ultramaroon (03-22-2021), Wally86 (03-23-2021)
Old 03-22-2021, 06:45 PM   #10
Ultramaroon
not playing cards
Excellent. Now, here's my take. Once you've found the first and second gear gates, align the plate so that so that the lockout foot rests against the plate when the gearshift is exactly in the middle of both first and second gear gates. It's a shortcut to using feeler gauges but I argue that, if one is careful, it's actually a better technique. The published procedure attempts to minimize opportunity for error.
YMMV. Getting the adjustment right is important to avoid wear in the long term. The actual parts for the gate mechanism are relatively delicate.
edit: When I say middle, I mean when the transmission is in gear. Engage first gear. Find the middle and adjust the plate. Do the same for second. It's an iterative process because the plate moves around so much and it's a single adjustment for both gates.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
MJones_RB (03-23-2021), PH03N1X (03-22-2021), theneptune86 (03-22-2021), Wally86 (03-23-2021)
Old 03-22-2021, 06:59 PM   #11
PH03N1X
PH03N1X's Avatar
Great tip. Thanks!
Old 03-23-2021, 03:33 PM   #12
MJones_RB
MJones_RB's Avatar
Tip: a quick shot of black spray paint, before you remove the lockout plate, will show you exactly where the plate goes when re-installing it.
MJones_RB is offline   Reply With Quote
The Following 2 Users Say Thank You to MJones_RB For This Useful Post:
PH03N1X (03-23-2021), Ultramaroon (03-23-2021)
Transmission 2nd gear grind ArchReactor86 Engine, Exhaust, Transmission 0 12-09-2019 11:08 AM
Transmission, Shifter help please Nightflo Issues | Warranty | Recalls / TSB 4 04-12-2018 01:29 PM
Rattling Gear Shifter Above 5k RPM alchemy Issues | Warranty | Recalls / TSB 4 03-21-2016 01:21 AM
5th gear vibration in Shifter - anyone else? EsoBOFH Issues | Warranty | Recalls / TSB 7 12-03-2015 03:55 PM
transmission grind in 5th gear Rocket.BRZ Issues | Warranty | Recalls / TSB 7 06-30-2014 11:38 PM
