Old 04-11-2018, 03:36 PM   #1
Nightflo
Nightflo's Avatar
Transmission, Shifter help please
Hey guys,
After about 2 years of installing the kartboy shifter, my shifter just completely got weird. When I try shifting into first, it goes into reverse without me pulling the reverse lockout. As for when I shift into 2nd, it won’t go in at all.
Now here’s the weird part, I still have 1st and 2nd gear but they’re located right next to 3rd and 4th. So instead of pushing my shifter left and up for 1st or left and down for second, I have to push it SLIGHTLY left and then up FOR 1st or SLIGHTLY left and then down for 2nd instead of ALL THE WAY left and up or down.
I talked to Subaru master tech and he said I installed it wrong so I opened it up and check but nothing looked off. I’m thinking the lockout broke and now I need a new shifter?
I HAVE NO IDEA WHAT IT IS.
Can somebody help me?
Nightflo
Fresno, CA
BOOSTED ‘15 BRZ
Since ‘14
Nightflo is offline   Reply With Quote
Old 04-11-2018, 07:45 PM   #2
humfrz
I have heard that sometimes something in the shifter becomes unhinged.
I'd suggest you look for a loose or missing pieces.
Others will be along with more specific help .....
humfrz
Nightflo (04-12-2018)
Old 04-12-2018, 12:57 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
your cap plate is out of adjustment.
https://demos.starbase7.net/t3Portal...05HBC002X.html
Nightflo (04-12-2018), Overdrive (04-12-2018)
Old 04-12-2018, 02:27 AM   #4
Nightflo
Nightflo's Avatar
Yup, you’re right! Thank you. Figured it out this morning but if I hadn’t figured it out, you legit had the quick and easy answer if resort too.
Nightflo
Fresno, CA
BOOSTED ‘15 BRZ
Since ‘14
Old 04-12-2018, 12:29 PM   #5
humfrz
Yaaaaaa!...........Ultramaroon fixes another one ......
humfrz
help please, kartboy, shifter, transmission
(SOLD) Kartboy Rear Shifter Bushing and Transmission Mount Insert Asidrive Transmission and Driveline 2 04-13-2018 01:44 PM
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 09:57 PM
Six speed manual transmission 17k miles, kart boy short shifter AZ Cross Transmission and Driveline 9 12-12-2014 07:37 PM
Rear Shifter/Transmission Mount Insert Bushings TheseColorsDontRun Mid-Atlantic 7 08-30-2013 10:29 AM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-09-2012 08:40 PM
