Old 03-21-2021, 07:30 PM   #1
Thatguykr
Exclamation Transmission Position Sensor Location
My 2013 Scion FR-S had these codes. I tried to look up where the location of the transmission range sensor but I couldn’t find any thing. My FR-S has problems with reversing. I would put the car in reverse and it either doesn’t move or it goes really really slow. All help is appreciated. Thank you!
Thatguykr is offline   Reply With Quote
The Following User Says Thank You to Thatguykr For This Useful Post:
humfrz (03-21-2021)
Old 03-21-2021, 09:20 PM   #2
humfrz
Hi ya, Thatguykr , and welcome to our forum -
I would suggest that you just take your car into a dealer and ask them to fix it.
Why into a dealer? Because, even if you found it and replaced it, unless it is set/calibrated/adjusted properly, it could screw up the whole transmission.
If you want to know what it looks like and where it is located, you may check here:
https://demos.starbase7.net/t3Portal/
(compliments of ol Ultramaroon)
Ultramaroon (03-21-2021)
Throttle Position Sensor [Suspected Faulty] Hags86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 09-29-2025 10:05 AM
Camshaft Position Sensor Or VVT ? Dacfrs DIY (Do-It-Yourself) Guides 4 10-28-2020 08:38 AM
How to Access Camshaft Position B Sensor? exittoexist Scion FR-S / Toyota 86 GT86 General Forum 1 01-26-2020 10:11 AM
Wrong O2 sensor position in almost all headers! JIM THEO Engine, Exhaust, Transmission 15 09-01-2018 12:05 PM
How to calibrate Throttle position sensor FRS? Binary_fission Issues | Warranty | Recalls / TSB 11 04-01-2017 01:37 AM
