Old 03-28-2020, 08:28 PM   #1
Dacfrs
Drives: Reddy Whip
Camshaft Position Sensor Or VVT ?
Ok, I've searched the forum, but don't see this particular issue anywhere. My 13 FRS has thrown a po366 code, which my code reader says is "camshaft position sensor B circuit range/ performance bank 1". It would seem to me that the CPS and VVT are working in tandem...replace one and you should also replace the other. Just looking for some clarification....Thanx
Dacfrs is offline   Reply With Quote
Old 06-05-2020, 02:12 PM   #2
TwinsLife
Drives: WRB 14 BRZ
Did you get an answer to this or figure out issue? Throwing a p0345 on sensor A bank 2 but I don't know which sensor that is. I assume driver side but dont know if its bottom or top.
TwinsLife is offline   Reply With Quote
Old 06-07-2020, 11:11 AM   #3
gcranston
Drives: 2015 Subaru BRZ Limited DGM
Did you change the oil? I had P0365. Start with an oil change. The cam geometry (for valve timing) works by pumping oil in and out and if it's low or dirty it can get messed up.
Are you still under warranty? If so, and the oil change doesn't fix it, the dealer will replace the sensor.
gcranston is offline   Reply With Quote
Old 06-07-2020, 12:29 PM   #4
solidsnake11
Drives: brz
The Cam Position Sensor only tells the ecu where the cam is compared to the crank. The computer changes the duty cycle of VVT actuator to hit the commanded cam angle. The computer has limits on how far it can change duty cycle to hit the target.
Your problem could be the actuator, sensor, phaser, or out of timing.
solidsnake11 is offline   Reply With Quote
Old 10-28-2020, 08:38 AM   #5
DoubleV
Drives: 2013 Toyota GT86
Did you find what was wrong with your car?
I'm getting a P0341 and everything around VVT in TechStream software is set to 0 (VVT OCV, Target VVT angles, etc..)
https://www.ft86club.com/forums/showthread.php?t=142891
DoubleV is offline   Reply With Quote
How to Access Camshaft Position B Sensor? exittoexist Scion FR-S / Toyota 86 GT86 General Forum 1 01-26-2020 10:11 AM
P0021 OBD-II Trouble Code: Camshaft Position A - Timing Over-Advanced kingaron06 Engine, Exhaust, Transmission 4 12-11-2018 03:08 AM
P0021 OBD-II Trouble Code: Camshaft Position A - Timing Over-Advanced kingaron06 Issues | Warranty | Recalls / TSB 2 12-11-2018 12:40 AM
Replacement camshaft sensor plug? execute1902 Issues | Warranty | Recalls / TSB 4 06-09-2017 01:52 AM
New TSB for camshaft sensor whitefrs Issues | Warranty | Recalls / TSB 13 03-11-2014 02:54 PM
