Old 03-14-2021, 03:49 PM   #1
decalls
Drives: wrapped subaru brz 2016
Subaru Brz Wont start
hey so im having some trouble with my brz and was wondering if anyone else has the same problem. After doing a couple donuts my car dies out and throws a u0100 code. When it happen in the past i would have to depress the clutch and the car would burble and sound as if its dieing but then it would come back. This time my car wont start at all and i still have the same code. Anybody can help me out please?
decalls is offline   Reply With Quote
The Following User Says Thank You to decalls For This Useful Post:
humfrz (03-15-2021)
Old 03-14-2021, 04:18 PM   #2
FLIPDADY
FLIPDADY's Avatar
Drives: 2015 Subaru BRZ Sport Tech
Sounds like what happened with my BRZ a few weeks ago. Except I attempted to start the car while both mufflers were covered in a snow bank. After continuously trying to turn the car over. It wouldn't go. Turns out I flooded the engine. Didn't get any codes just the no start. Pulled the plugs and cleaned them up. All good to go now.
Sent from my LM-G900 using Tapatalk
FLIPDADY is offline   Reply With Quote
The Following User Says Thank You to FLIPDADY For This Useful Post:
humfrz (03-14-2021)
Old 03-14-2021, 04:20 PM   #3
humfrz
Hello decalls and welcome to our forum. -
First off, stop doing donuts - - it's hard on your car.
Second off, check out this reference:
https://www.solopcms.com/blog/common...0100-code-fix/
Third off, wait for someone to come along that knows what they are talking about to help you out -
Old 03-14-2021, 04:28 PM   #4
humfrz
You make that sound easy - have you had an engine transplant? -
BrahmaBull1990 (03-14-2021), Ohio Enthusiast (03-15-2021)
Old 03-14-2021, 05:09 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
u0100 is a loss of communication. i would check your grounds, as well as fuses.
are there any mods to the car?
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
BrahmaBull1990 (03-14-2021), Ultramaroon (03-14-2021)
Old 03-14-2021, 07:47 PM   #6
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
An you decided that continuing to do the thing was a good idea...
Old 03-15-2021, 11:54 AM   #7
humfrz
Do you mean the engine won't turn over ...... or ..... won't fire?
Tcoat (03-15-2021)
Old 03-15-2021, 01:29 PM   #8
Is your battery low?
Old 03-16-2021, 08:11 PM   #9
soundman98
soundman98's Avatar
have you checked the planetary alignment?
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
alex87f (03-18-2021), BrahmaBull1990 (03-17-2021), NoHaveMSG (03-16-2021)
Old 03-16-2021, 10:14 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Is Mercury in retrograde?
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
BrahmaBull1990 (03-17-2021), soundman98 (03-18-2021)
Old 03-17-2021, 01:11 PM   #11
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
OP did not provide enough detail...he failed to mention the condition of his car after the donuts..found his car on his FB page..
surprised it only has one code..
HKz is offline   Reply With Quote
The Following 4 Users Say Thank You to HKz For This Useful Post:
BigHugeFatGuy (03-21-2021), BrahmaBull1990 (03-17-2021), NoHaveMSG (03-17-2021), soundman98 (03-18-2021)
Old 03-17-2021, 01:28 PM   #12
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
HKz (03-17-2021)
Old 03-18-2021, 08:48 PM   #13
soundman98
soundman98's Avatar
for a second there, i thought the tire was on fire.
HKz (03-19-2021)
Old 03-19-2021, 12:21 PM   #14
extrashaky
Drives: 2014 BRZ Limited
Seems like I remember reading something about fuel starvation from the design of the fuel tank during extreme lateral Gs. There's an insert you can install that prevents it.
That wouldn't cause the U0100, but it might explain why it quit. You could have multiple things going on.
FRS Wont Start CG3TZ Issues | Warranty | Recalls / TSB 16 10-18-2020 04:40 PM
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 09:35 PM
FR-S wont start or click... KingLos Issues | Warranty | Recalls / TSB 3 12-02-2016 01:38 AM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 01:01 AM
URGENT : CAR WONT START DarkCard Engine, Exhaust, Transmission 9 08-01-2013 08:57 PM
