Drives: 2016 Scion FRS Release Series 2#439
Titanium Brake Pad Shields
Is anyone with the PP Brembo’s, or others for that matter, using Titanium Brake Pad Shields to block heat transfer from pad to caliper/pistons?
What are your impressions? Effective, or gimmick? |
ProCrastinationConsultant
gimmick.
titanium has only a slightly lesser thermal conductivity than standard steel. at the material thicknesses of the backing plate vs the pad material thickness(which would maintain and enhance the thermal load), if you're having issues with steel backing plates, you're going to have the exact same issues with titanium backing plates-- it just might be half a braking zone further on.
Drives: Crapcan
People put backing plates back in
![]() Sent from my iPhone using Tapatalk
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Icecreamtruk (03-15-2021) |
Thanks for the confirmation.
I hadn't seen any discussion about them here so thought I'd ask. Cheers! |
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Nascar brakes have a ring that reduces the conductivity. Besides that, a shield would only work for convective and radiative heat transfer (if it is the case)
| SOLD: Titanium brake shims | BatStig | Canada Classifieds | 25 | 01-18-2016 11:25 AM |
| Heat Shields | X Factor | Engine, Exhaust, Transmission | 4 | 09-05-2014 03:47 PM |
| SOLD: Touge Factory Brake Cooling Kit + Titanium Shims | ATL BRZ | Brakes, Suspension, Chassis | 2 | 07-22-2014 01:59 PM |
| Titanium Brake Pad Shims - worth it? | 96z2 | Tracking / Autocross / HPDE / Drifting | 16 | 09-27-2013 01:00 PM |
| weather shields for the 86.. | Slide | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 01-18-2012 05:04 AM |
