Old 02-09-2021, 08:47 AM   #1
abyssFT86
Drives: 2020 BRZ Limited
Track wheel that clears performance package
Howdy,
I just bought a 2020 BRZ w/ Performance Package. It is replacing my 2002 RSX Type-S as a track car (Laguna Seca primarily, perhaps Thunderhill).
I want to get better tires before running it out there and like the RPF1s (have them on the Acura). I read here that 17x9 +35 does not clear the performance package brakes even with spacers, so I think I would have to drop width to 17x8 +35 which apparently fits with no issues.
Some other wheels (Like Gram Lights 57CR) fit in 17x9 +35/38, but weigh a good 3+ lbs more. I am at a bit of a crossroads here.
1.) Is it better to lose the extra tire width for the lighter wheel?
2.) Are there other good lightweight options in 17x9 that fit with PP that I should look into besides RPF1? Guessing there is something but haven't seen in in the various wheel threads I've scrolled through here.
Thank you!
abyssFT86 is offline   Reply With Quote
Old 02-09-2021, 09:01 AM   #2
RenegadeWRX
Drives: 2013 BRZ 1999 Subaru Impreza
I love my APEX ARC 8 wheels 17x9 +42 look good and aren't too heavy.
Sent from my SM-N986U using Tapatalk
RenegadeWRX is offline   Reply With Quote
Old 02-09-2021, 11:31 AM   #3
Code Monkey
Drives: Subaru BRZ
APEX or 6UL.
Code Monkey is offline   Reply With Quote
Old 02-09-2021, 02:17 PM   #4
Rigidity > weight.
Don't let more weight scare you, especially if you're riding berms, or occasionally go off.
Old 02-09-2021, 04:14 PM   #5
TunaNoCrust
TunaNoCrust's Avatar
Drives: 86, 981S, RX8, 2500HD, GenesisV8
On my 2019 86 TRD I am running the Konig Hypergrams 17x9, 40mm Offsets and I aggressively frequent the curbing.
If you find a 35mm or less wheel that fits, please post up!
TunaNoCrust is offline   Reply With Quote
Old 02-09-2021, 08:29 PM   #6
abyssFT86
Thank you for pointing me to the Apex wheels, the EC-7R look amazing and only ~1.9 lb heavier than the RPF1. That looks like the move for me.
I see that I could go with 9" (stock suspension) or 9.5" wide (requires coilovers, I *think*). I don't have coils yet. Is it worth getting them to do the 9.5" wheel? Do I even want a wheel that wide? Eventually want to set this car up with a Jackson racing supercharger.
EDIT: And maybe a dumb question, but I assume the 17" is a better option than 18" for track purposes? Assume that's the case but the 18" in gold looks amazing...
Old 02-09-2021, 08:38 PM   #7
colobrio
Drives: 2013 BRZ, 6MT, WR Blue
Wedsport tc105 is pricier, but another popular option.
colobrio is offline   Reply With Quote
Old 02-09-2021, 08:52 PM   #8
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Generally speaking, 17" tires are more affordable than 18" ones. There seems to be bigger jumps around 18 and 19". That's one thing to factor in - especially when considering autox/track sets of wheels.
Second is weight. 18 wheels are generally the same weight, if not heavier than 17". 18" tires are generally the same weigh as 17" or heavier. The net result is an overall package that's heavier. Especially on a lower power car, you don't want have way too much tire than you realistically need.
cmiovino is offline   Reply With Quote
Old 02-09-2021, 08:59 PM   #9
Sphinx
Drives: 18 BRZ PP & 99 Spec Miata
With people breaking axles as it is, going with a wider tire and heavier wheel would mean more stresses on the axles if you are going to be tracking the car. Personally I wouldn't go wider than 17x9.
2018 BRZ 50th Anniv Performance Package, stock
1999 Spec Miata
Sphinx is offline   Reply With Quote
Old 02-09-2021, 09:03 PM   #10
RenegadeWRX
Yeah I've been running 17x9 with 245 re71r tires and haven't had issues or seen issues at that size. I did have some 18x10s on there with some 265 nittos on them but it didn't seem to have an issue with them although I didn't track or autocross with those wheels.
Old 02-09-2021, 09:06 PM   #11
abyssFT86
Perfect. I think the 17x9 EC-7R is exactly what I want then. Now to wait for it to come back in stock! :P
Old 02-10-2021, 08:36 AM   #12
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
+1 for 17x9 +40 6UL's.
Breezio is offline   Reply With Quote
Old 02-10-2021, 02:12 PM   #13
Pat
Pat's Avatar
Drives: 2023 BRZ
Rigidity > weight.
I'm glad you mentioned this. Finding the weight of wheels is pretty easy. Unfortunately rigidity information is much more difficult to find. I know lack of flex is a huge benefit to carbon wheels, but that's not really a realistic option for 86 owners. So how do we figure out which wheels are the most rigid? I discussed this with Ryan at Apex a couple weeks ago, but he didn't have any info for me. He said he'd check with his engineers. I thought that would be a great topic to add to their already excellent blog.
Old 02-10-2021, 03:21 PM   #14
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
Just FYI.. There's a thread in the Wheels & tires forum about which wheels will clear the PP brakes.
https://www.ft86club.com/forums/showthread.php?t=135328
That should provide a good start for a list of stuff confirmed to fit. you can then shop for your choice of style, weight, size, etc etc etc.
Matt93SE is offline   Reply With Quote
QueenBRZ's 17' BRZ performance package DD / track build QueenBRZ Member's Car Journals 125 06-29-2021 01:34 PM
2017 BRZ Performance Package Wheel Clearance Concerns DG-86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 47 08-11-2020 11:05 PM
Stock wheel alignment values for Performance Package (are they different?) cenci Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-24-2019 11:50 PM
Looking for Brz OEM 17 wheel for performance package khcho19 Want-To-Buy Requests 1 04-27-2018 11:09 AM
Can I use STI black alloy wheel on 2018 brz with performance package? khcho19 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 04-24-2018 09:51 AM
