Old 04-24-2018, 03:14 AM   #1
khcho19
Drives: ford focust ST
Can I use STI black alloy wheel on 2018 brz with performance package?
Hi All,
I have a 2018 BRZ limited performance package.
It comes with brembo brakes and 17" 10 spoke alloy wheels.
However, I want to replace the wheel to STI black alloy wheel (17" 15 spoke, part # 28111CA060,
https://parts.subaru.com/p/Subaru__B...8111CA060.html)
Do you think it will fit to the BRZ without any problem to installed brembo brakes?
khcho19 is offline   Reply With Quote
Old 04-24-2018, 07:04 AM   #2
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
It should fit if it's 17x7,5 version of this wheel. If I remember correctly there are two versions of this design in 17 inch. One of them is 17x7 and second one is 17x7,5 (JDM market one?). The wider one should fit without issues - someone on forum put them on series yellow BRZ:
http://www.ft86club.com/forums/showp...4&postcount=75
MrSkubi is offline   Reply With Quote
Old 04-24-2018, 09:51 AM   #3
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
No you cannot use the 17" black STI wheels that are an option on the non-PP. They won't clear the brakes. You could use very large spacers to get them to fit, but you'll need longer studs to accomplish that and frankly I don't recommend it.
The 18" wheels from the tS will fit just fine if you want that look and don't mind going to 18's. Also, the black version of the stock PP wheels from the Series.Yellow also fit if it's just color you're going for.
trippinbillies40 is offline   Reply With Quote
2017 BRZ Performance Package Wheel Clearance Concerns DG-86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 47 08-11-2020 11:05 PM
BRZ STi Alloy Wheel Size and Offset? artongdou Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 06-09-2017 07:17 PM
Alloy space saver wheel churchx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 11-03-2016 09:43 AM
*Wheels Collection* Winter Package 2015-2016 (Alloy Wheels + Tires) wheelsco Canada Classifieds 4 10-08-2015 03:55 PM
Zinc Alloy "86 logo" key rings $9.99 (red or black), LED lighting & other USA Stock! WTF Miscellaneous 0 04-10-2013 03:51 AM
