Old 11-21-2020, 04:39 AM   #1
GivoFrz86
GivoFrz86's Avatar
Drives: 2017 Toyota 86
Exhaust Drone
Hello, So I have a 2018 Brz Ts and I am running Tomei UEL Headers, Berk Test pipe, and the ft86 x Remark catback, and I have some terrible drone between 2-3k rpm. I was wondering what you guys recommend that I do in order to help reduce the drone.
GivoFrz86 is offline   Reply With Quote
Old 11-21-2020, 10:45 AM   #2
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Stock front pipe
gen3v8 is offline   Reply With Quote
The Following 6 Users Say Thank You to gen3v8 For This Useful Post:
DarkPira7e (11-21-2020), HaXx (11-21-2020), marky (11-28-2020), RToyo86 (11-21-2020), strat61caster (11-21-2020), Tcoat (11-24-2020)
Old 11-21-2020, 11:42 AM   #3
GivoFrz86
GivoFrz86's Avatar
Originally Posted by gen3v8 View Post
Stock front pipe
You think if I were to get a high flow cat front pipe it would reduce the drone?
Old 11-21-2020, 12:29 PM   #4
jflogerzi
jflogerzi's Avatar
Look at these 2 options:
HKS Dual resonator or the JDL Ultra quiet FP. But in all honesty Stock FP will do it for free and you will not even notice the HP drop.
2013 Series 10 FRS #553
Old 11-21-2020, 12:39 PM   #5
GivoFrz86
GivoFrz86's Avatar
So my car has a pop tune if I were to put the front pipe back on would i have to get rid of the pop tune?
Old 11-21-2020, 12:55 PM   #6
jflogerzi
jflogerzi's Avatar
No. It will reduce the effect of the tune and might reduce the cat life a bit.
Old 11-21-2020, 01:24 PM   #7
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
There are those who would suggest that no matter what you do to the exhaust (or any other part of the car for that matter) that it would be greatly appreciated and downright neighborly if you "get rid of the pop tune".
LimitedSlip is offline   Reply With Quote
The Following 2 Users Say Thank You to LimitedSlip For This Useful Post:
CrowsFeast (12-07-2020), Tcoat (11-24-2020)
Old 11-21-2020, 01:27 PM   #8
Frankz54
Drives: 2019 Toyota GT86
I have a 2019 with the same setup as yours. I had to get a 24inch resonator installed. The drone was really really bad inside the car. Now with the resonator it's more quite and you can actually enjoy it. Only down fall was you have to cut the exhaust pipe to add it. But i do enjoy the remark quad exhaust.
Frankz54 is offline   Reply With Quote
The Following User Says Thank You to Frankz54 For This Useful Post:
NoHaveMSG (11-23-2020)
Old 11-21-2020, 01:42 PM   #9
GivoFrz86
GivoFrz86's Avatar
Do you still have drone but its quite and doesn't vibrate the car, or is your drone completely eliminated?
Old 11-21-2020, 01:43 PM   #10
GivoFrz86
GivoFrz86's Avatar
Why?
Old 11-21-2020, 03:55 PM   #11
GivoFrz86
GivoFrz86's Avatar
Originally Posted by beltax90 View Post
Can you give me a little detail on where it fits and how the exhaust piping would work?
Old 11-21-2020, 04:13 PM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
I have Tomie UEL, Miltek OP, Berk fast cat FP, the rest is standard OEM, sounds good. Trundling about it's pretty quiet, open it open it gets "sporty" without getting over the top.
Old 11-21-2020, 04:19 PM   #13
GivoFrz86
GivoFrz86's Avatar
At first I only had the UEL headers and Berk FP, and the rest oem but I didn't like it because it had no tone it was just subie rumble and it didn't sound too good, but do you have any clips im interested to see how yours sounds.
Old 11-21-2020, 04:36 PM   #14
JD001
JD001's Avatar
Drives: Subaru BRZ
Sorry, no clips. I will try and get some sounds.
Anyone else run into really bad exhaust drone? Turbo Forced Induction 24 09-08-2018 02:20 PM
TRD Exhaust drone. FenrirRedsteele Engine, Exhaust, Transmission 10 08-11-2018 08:44 AM
Help!!, exhaust too much drone/too loud.. BlaqkHavok Engine, Exhaust, Transmission 6 10-02-2017 10:27 AM
MLV for exhaust noise and drone? PandaSPUR Electronics | Audio | NAV | Infotainment 19 03-05-2016 10:13 AM
exhaust drone ZHoward Engine, Exhaust, Transmission 7 02-27-2016 11:03 PM
