Old 08-06-2018, 04:11 PM   #1
FenrirRedsteele
Drives: 2013 brz
TRD Exhaust drone.
hey all,
so i have a 2018 brz. and i put the TRD catback system on and for some reason i get some god awful drone right around 2-3k rpm if im off the gas / down shifting.
i plan on picking up the JDL catted + resonated FP/OP combo. i was wondering if this would help any with the drone? or if im better off swapping catback to like the q300.
thanks in advance
FenrirRedsteele is offline   Reply With Quote
Old 08-06-2018, 04:22 PM   #2
norcalpb
norcalpb's Avatar
Do you currently have catless headers?
Old 08-06-2018, 04:47 PM   #3
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
There is some drone with this exhaust, but if you JUST got the muffler give it some time to break in. New exhausts are louder and need time to carbon up over the first 1000 miles of use.
Lincoln Logs is offline   Reply With Quote
Old 08-06-2018, 04:49 PM   #4
FenrirRedsteele
Drives: 2013 brz
Completely stock setup. And I got them used for 200$ as a deal. Not sure if theres something wrong but I'm a welder and inspected all the welds and saw no issues
Old 08-06-2018, 04:51 PM   #5
FenrirRedsteele
Drives: 2013 brz
Will what I posted help with the drone at all? I knew there was some with it but this seems like more then normal? Km not too technical with exhausts I apologize
Old 08-06-2018, 05:48 PM   #6
Lincoln Logs
If the exhaust was used then it is probably already broken in, and the price you paid was a steal! That is pretty characteristic of this exhaust to drone during that RPM range.
Assuming there are no leaks your ears just might be more sensitive to that frequency of noise. If they are I'd recommend selling it for a Thermal R&D exhaust. It features a helmholtz chamber which cancels out the bad sound frequencies and if you keep the stock front pipe with the header the overall dB is very nice for a street car.
Old 08-08-2018, 03:02 AM   #7
humfrz
hey all,
thanks in advance
Oh, I'd suggest give it some time - you will most likely get used to it -
humfrz
Old 08-08-2018, 03:03 AM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
hey all,
thanks in advance
If you're getting a header, I'd adjust your exhaust setup if drone bothers you. The TRD exhaust is known to drone at that RPM range and that's one of the reasons I personally avoided it. In my case I have 0 drone with a catless UEL and nameless axleback and downpipe combo. The downpipe replaces the factory overpipe and front pipe and makes it all one piece.
If you're doing a full exhaust I'd keep the catted UEL, but go with something like a nameless downpipe with helmholtz resonator and 2.5 inch axleback with 5 inch mufflers as the stock midpipe doesn't yield any gains when swapped out:
https://shop.namelessperformance.com...rpipe-brz-frs/
The stock midpipe contains it's own muffler/resonator as well. The thermal R&D exhaust someone else mentioned would be a good idea as well. Both use resonators to cut down on the drone frequencies.
If you like I can send a video of my exhaust setup, as it's got the setup I've mentioned, I believe with your catted UEL it'd be more tame.
Old 08-08-2018, 11:41 AM   #9
mrg666
pessimistic skeptic
mrg666's Avatar
If you have not done these yet, I would recommend a new donut gasket and using Permatex copper RTV in the other two joints before the muffler.
Old 08-10-2018, 01:45 AM   #10
FRSBRZGT86FAN
What mrg66 said as well, grimmspeed gaskets and high temp rtv killed any leaks I had in my header. It seems some aftermarket equipment has trouble mating properly in some cases.....
Old 08-11-2018, 08:44 AM   #11
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
I had drone with a jdl catless headers, switched front pipe to hooker catted with helmholz resonator. It helped for sure. Still. Some base drone at 2k, but manageable.
Ernest72 is offline   Reply With Quote
Help!!, exhaust too much drone/too loud.. BlaqkHavok Engine, Exhaust, Transmission 6 10-02-2017 10:27 AM
MLV for exhaust noise and drone? PandaSPUR Electronics | Audio | NAV | Infotainment 19 03-05-2016 10:13 AM
exhaust drone ZHoward Engine, Exhaust, Transmission 7 02-27-2016 11:03 PM
surprise fix for exhaust drone ogrowup Scion FR-S / Toyota 86 GT86 General Forum 0 03-17-2015 08:40 PM
DRONE!!! full exhaust Victor Draken Engine, Exhaust, Transmission 23 06-02-2014 06:52 PM
