Old 10-02-2017, 03:11 AM   #1
BlaqkHavok
Drives: 2014 DGM BRZ
Help!!, exhaust too much drone/too loud..
hey guys, got a particular issue, and just need some feedback by those who are more expirienced with variouse exhaust set-ups on the 86.
first thing the car:
16 frs auto
Ptuning header
tomei overpipe
Nvidia catted frontpipe
Ptuning catback exhaust.
so right now the owner like the sound when under full throttle, especially at higher RPMs, but... the drone, when cruzing between 2100 and 3500 RPMS under low throttle (65mph to 80mph), is too loud, and abrasive...
the part that sux, is that, that is the only time that the exhaust is too much...
to those who do custom exhausts, or have tweeked production systems, i was thinking of the aeroturbine resonator... what are the thought on that? and what size should be fitted, i belive they are none glass packed resonators that use a sort of venturi effect to help cancel out exhaust sound wile minimizing impact on exhaust velocity...is that a good solution? or is there something else i can do or product that would work better?
thank you in advance to any who can help point me in a proper direction for a fix..
BlaqkHavok is offline   Reply With Quote
Old 10-02-2017, 07:26 AM   #2
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I had the same problem living in a RV park. I went with the Invidia Q 300 exhaust and HKS dual resonated front pipe. Nice and quiet now but still sounds good when getting on it.
Lunatic is offline   Reply With Quote
Old 10-02-2017, 08:22 AM   #3
Cole
Not a troll
Cole's Avatar
Start by putting your stock front pipe back on
Old 10-02-2017, 09:15 AM   #4
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
This ^^. Resonated front pipe will definitely help the drone.
DaBoBo21 is offline   Reply With Quote
Old 10-02-2017, 09:32 AM   #5
jasonojordan
Drives: 2013 satin white brz limited
I did something similar with mine. I have the Q300 but went with the ACE resonated front pipe. Very quiet at idle/low load. But has a nice tone to it when you have your foot into it.
jasonojordan is offline   Reply With Quote
Old 10-02-2017, 09:43 AM   #6
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
JDL Ultra quiet front pipe, hks dual resonated front pipe, something like that should help.
If not, add a big vibrant resonator to the front pipe.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 10-02-2017, 10:27 AM   #7
A CSGxMXP Touring86 would eliminate all drone without hurting flow at all
Brz Corsa Exhaust Video (No drone!) notorious9i6 Engine, Exhaust, Transmission 19 10-05-2017 01:30 PM
MLV for exhaust noise and drone? PandaSPUR Electronics | Audio | NAV | Infotainment 19 03-05-2016 10:13 AM
exhaust drone ZHoward Engine, Exhaust, Transmission 7 02-27-2016 11:03 PM
surprise fix for exhaust drone ogrowup Scion FR-S / Toyota 86 GT86 General Forum 0 03-17-2015 08:40 PM
DRONE!!! full exhaust Victor Draken Engine, Exhaust, Transmission 23 06-02-2014 06:52 PM
