Old 10-11-2020, 04:44 PM   #1
pakunodafie
Drives: Toyota GT86
Angry Clunking noise in uneven road. Please Help.
Hello Guys, It's started last week. I have a clunking noise on my rear driver side, At first I thought only personal things on the trunk making the noise. But today I sorted out, Removed everything in the trunk, spare tire, jacks, stands and secure all seatbelts. Tries to run it in the parking lot and unfortunately the clunking noise is still there.
When the car is turned off and I give force up and down at the rear there is still a clunking noise.
When the car is on drive and in uneven road rear side of the car having a clunking noise. Here is the audio recorded a while ago.
While car is turn off.
Audio file:
https://drive.google.com/file/d/1DtO...w?usp=drivesdk
When driving low speed: (noticable after acceleration, and gas is not pressed)
https://drive.google.com/file/d/1Dw0...w?usp=drivesdk
Please help guys. Thanks in advance.
pakunodafie is offline   Reply With Quote
Old 10-12-2020, 12:15 AM   #2
pakunodafie
Drives: Toyota GT86
bump
Old 10-12-2020, 02:52 AM   #3
humfrz
Audio file:
Well, pakunodafie , lets start with an obvious question, are all the lug nuts tight?
If so, you may wish to check the axle nut on that side to make sure it's tight.
What, if anything, have you done with the rear suspension lately?
If you can make that sound when the car is stopped, I suggest you stick your head under the car and have a friend push it up and down on the car to see if you can isolate where the sound is coming from.
I hope you get it sorted out.
Old 10-12-2020, 05:49 AM   #4
pakunodafie
Drives: Toyota GT86
Hi, All bolts and nuts are tighten down, There's no modification in the suspension. Completely stock except for the Invidia N1 and Wheels.
Cannot manage to lift the car but seems the problem is the shock absorber, But not 100% sure if only bushing, swaybar or anything in suspension.
Another observation is: The sound trigger when the shocks or spring bounced back. Not on the initial bounce.
Old 10-12-2020, 10:21 AM   #5
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Do the wheels have hubcentric spacers, or are they the correct size?
Old 10-12-2020, 11:22 AM   #6
pakunodafie
Drives: Toyota GT86
They do have hub centric spacers. And checking they are in correct size and fits perfectly.
Old 10-12-2020, 12:37 PM   #7
humfrz
OK, plan B. Take your car to a shop and put it up on a lift, so that you and a second pair of ears and eyes can get a better look to find out what is lose.
Old 10-12-2020, 04:53 PM   #8
pakunodafie
Drives: Toyota GT86
Will visit garage tomorrow and ill update you guys what they find out, I hope some loose under panel, or bolts need tighten or bushing only.
Old 10-12-2020, 05:07 PM   #9
davidsn_670
Drives: 2015 Scion FRS
Sounds like rear sway bay end links to me. Disconnect that side and see if the noise goes away.
davidsn_670 is offline   Reply With Quote
Old 10-12-2020, 06:15 PM   #10
anticubus
Drives: 2017 Toyota 86
I'm 99% sure this is the answer. Sway bar links are pretty common problems with rough roads. They clunk as they bang around in the mounting hole when the sway bar would otherwise be moving, usually because they've been vibrated loose or took a nice violent hit (pothole country represent) and ended up with damage (I've had mine bent and/or stripped and rusted loose).
If you've got rust issues you may need an angle grinder for removal (Be mindful of the shafts and other important bits nearby, they're expensive when you cut through them). Beyond that, it's a pretty simple and easy change. With the car on stands use a jack to lift the suspension to the point the sway bar is unloaded, then loosen and remove the link, put the new one in, and then tighten it down and load the suspension again. Like an hour tops if they're not frozen or stripped.
anticubus is offline   Reply With Quote
Old 10-13-2020, 12:37 AM   #11
pakunodafie
Drives: Toyota GT86
Hi, You mean this one?
or This one?
Or both need to replace?
Old 10-13-2020, 12:41 AM   #12
pakunodafie
Drives: Toyota GT86
That would help a lot, Thanks I'm visiting garage later and ill let them know which one to check first. Hope this will resolve my issue, Will update you soon guys,
Old 10-13-2020, 10:23 AM   #13
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
or This one?
The top photo is referring to the end links. Though the specific photo you show are the front end links.
Dzmitry is offline   Reply With Quote
Old 10-13-2020, 11:06 AM   #14
pakunodafie
Drives: Toyota GT86
Hi can you provide a part number or a link from ft86? Would help me a lot.
Clunking noise help MotoX16 Issues | Warranty | Recalls / TSB 41 03-02-2022 08:17 AM
Clunking noise in uneven road. Please Help. pakunodafie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-13-2020 12:44 AM
FR-S Clunking noise when driving Aydrian Issues | Warranty | Recalls / TSB 5 08-04-2019 06:03 PM
Tire Clunking Noise darko Issues | Warranty | Recalls / TSB 5 04-01-2016 02:57 PM
clunking noise after LCA install starron Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-17-2015 04:02 PM
