Old 10-11-2020, 04:42 PM   #1
pakunodafie
Drives: Toyota GT86
Clunking noise in uneven road. Please Help.
Hello Guys, It's started last week. I have a clunking noise on my rear driver side, At first I thought only personal things on the trunk making the noise. But today I sorted out, Removed everything in the trunk, spare tire, jacks, stands and secure all seatbelts. Tries to run it in the parking lot and unfortunately the clunking noise is still there.
When the car is turned off and I give force up and down at the rear there is still a clunking noise.
When the car is on drive and in uneven road rear side of the car having a clunking noise. Here is the audio recorded a while ago.
While car is turn off.
Audio file: https://drive.google.com/file/d/1DtO...w?usp=drivesdk
When driving low speed: (noticable after acceleration, and gas is not pressed)
https://drive.google.com/file/d/1Dw0...w?usp=drivesdk
Please help guys. Thanks in advance.
pakunodafie is offline   Reply With Quote
Old 10-12-2020, 12:14 AM   #2
pakunodafie
Drives: Toyota GT86
bunp
Old 10-12-2020, 10:01 PM   #3
norcalpb
norcalpb's Avatar
That sounds like something is loose. You can access nearly every rear suspension bolt without jacking up the car. Grab a 1/2" socket wrench and get started.
Be sure to also check the nuts in the trunk and do not overtighten them.
You will need a pass-through wrench + allen wrench to tighten down the rear shock nuts without spinning the shock shaft if that is loose. One nut per side, see pic below.
Old 10-13-2020, 12:44 AM   #4
pakunodafie
Drives: Toyota GT86
That would help a lot, Thanks Ill check with garage later and tell the to do this. Hopes that solve my clunking issues.
Clunking noise help MotoX16 Issues | Warranty | Recalls / TSB 41 03-02-2022 08:17 AM
FR-S Clunking noise when driving Aydrian Issues | Warranty | Recalls / TSB 5 08-04-2019 06:03 PM
ISC Control Arm Clunking and Noise megamarines Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-12-2016 03:28 AM
Clunking Noise After LCA Install Bach415 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 07-06-2015 03:24 PM
clunking noise after LCA install starron Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-17-2015 04:02 PM
