Old 10-04-2020, 01:29 PM   #1
hamish.frs
Drives: 2016 Scion FRS
Car getting stuck in gear / not going into gear
Hello guys,
I have been having the issue of my car refusing to get into gear or when it does get into gear, it doesnt want to come out of that gear. This issue only happens when the car is fully stopped.
Things i have done to try to fix this issue:
- bled the clutch system
- adjusted the clutch pedal
- adjusted the reverse lock bracket-
- changed the transmission fluid
- changed to a brand new aftermarket clutch
- changed my clutch fork
Car drove fine for 2 weeks but yesterday i went for a super long drive and it came back. Let me know your thoughts. Thanks 🙏.
hamish.frs is offline   Reply With Quote
Old 10-04-2020, 01:48 PM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
What clutch?
Old 10-04-2020, 02:46 PM   #3
hamish.frs
What clutch?
The previous clutch i had when the issue started was a ACT Stage 2 which was only 2k miles old. 2 weeks ago i changed to a southbend stage 2 endurance clutch and not even 200 miles in im having the same issue.
Old 10-04-2020, 11:04 PM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by hamish.frs View Post
Hello guys,
Just clarifying, the list is all things you have done AFTER this issue first appeared right? So sequence of events was:
1. Car drove fine
2. Car stopped letting you shift out of the blue.
3. Then you did all that troubleshooting. (Did you do it all at once or tried one at a time?)
4. Car drove fine for 2 weeks until you went for a long drive.
5. The issue came back exactly as before.
6. You posted here.
Please let us know if that is incorrect or if there are before/after/between parts of the story I missed.
Also, are there any abnormal noises?
Old 10-04-2020, 11:16 PM   #5
humfrz
Maybe your clutch cylinder or slave cylinder is bad?
Old 10-05-2020, 02:11 AM   #6
hamish.frs
1. Car drove fine
6. You posted here.
All of that information is correct. And for clarification for #3 yes i did do all that troubleshooting all at once. Thank you.
The Following User Says Thank You to hamish.frs For This Useful Post:
Spuds (10-05-2020)
Old 10-05-2020, 02:14 AM   #7
hamish.frs
Next thing im going to swap is the clutch cylinder for sure. But i posted here to see if theres anything else there could be. My car is still fairly new it only has 20,000 miles so it would be weird if my cylinders were giving out so early.
humfrz (10-05-2020)
Old 10-05-2020, 03:13 AM   #8
humfrz
Seems like you have covered most of the basis. True, one wouldn't think either of those cylinders would be bad, but, you never know.
Back in the day, we NEVER had ANY problems with clutch cylinders.
This is a test to see iffen you're payen attention - know why didn't we have any problems???????????
I hope you get it sorted out.
Tcoat (10-05-2020)
Old 10-05-2020, 06:36 AM   #9
Stock flywheel? Have you checked it's surface?
Old 10-05-2020, 08:44 AM   #10
Spuds
The Dictater
Spuds's Avatar
Hmmm... Any chance the transmission is misaligned with the shifter? I know it's a pretty direct connection, so not much to go wrong there. Maybe just a bad transmission mount or something?
Hypothesis is that when you replaced the clutch you realigned everything correctly, but then something in your longer drive caused it to shift out of alignment.
It does seem like a classic clutch problem though. If you are in gear with the car off and start the car with the clutch pedal pressed, does it still start?
Old 10-05-2020, 12:28 PM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Stock clutch fork?
Old 10-05-2020, 10:38 PM   #12
hamish.frs
Yep, stock flywheel. Only 15k miles on em, surface is fine
Tcoat (10-06-2020)
Old 10-05-2020, 10:39 PM   #13
hamish.frs
Doubt its misalligned, car shifts like butter in every gear till it randomly locks me out. And yes with the car in gear the car starts perfectly fine.
Spuds (10-05-2020)
Old 10-05-2020, 10:40 PM   #14
hamish.frs
Stock clutch fork?
Verus forged clutch fork, only on for about 100 miles
Gear indicator not registering 5 th gear on 6mt sroby Engine, Exhaust, Transmission 20 03-18-2020 11:43 PM
AT - 1st gear gets stuck and hits high RPM's before shifting undone14 Issues | Warranty | Recalls / TSB 7 05-27-2018 11:23 PM
1st & 2nd gear stuck? YoungChow Issues | Warranty | Recalls / TSB 11 07-24-2017 12:11 AM
Gear indicator (G-on) shows 2 when in 3rd gear c8Face BRZ First-Gen (2012+) — General Topics 31 07-07-2017 07:23 PM
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 06:28 PM
