Old 09-07-2016, 12:50 AM   #1
YoungChow
YoungChow's Avatar
Drives: FR-S 10 Series #2127
1st & 2nd gear stuck?
Hey guys I'm not sure if anyone has experienced this issue, I'm fairly new and haven't been able to find anything about it.
So basically as I was driving today just like any other day, I am at a stop light and i go to shift to 1st, but couldn't, kept going into 3rd, so i try 2nd, that takes me right into 4th.
After a little bit of playing around trying to get going at this stop light lol I find that if I lift the little thing to put it into reverse and go about halfway to reverse it'll allow me to go up into 1st or even 2nd.
Anyone know of what could fix this? everything was fine until earlier today. I mean it seems to engage fine once I'm able to find the gear.
YoungChow is offline   Reply With Quote
Old 09-07-2016, 01:02 AM   #2
humfrz
Hi YoungChow ......
Bummer your car isn't shifting proper......
Sounds to me like something in the shifting linkage has come unglued.
If your car is under warranty, I would suggest you take it into the dealer ASAP.
There are several threads that discuss this type of issue you may wish to review.
Calling @Tcoat to list them ......
humfrz
Old 09-07-2016, 01:20 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
I'll take a wild guess that you failed to mention you have a TRD short shifter kit installed.
Old 09-07-2016, 01:37 AM   #4
YoungChow
YoungChow's Avatar
Yep... not sure what you're poking at, if you could give me a little direction lol
Old 09-07-2016, 01:40 AM   #5
Ultramaroon
not playing cards
It came loose. It will keep coming loose because it's a shitty design. Some people have had luck using red loctite on the bolt.
Personally, I suggest removing it and chucking it in the trash.
Old 09-07-2016, 01:45 AM   #6
YoungChow
YoungChow's Avatar
Thanks for the information man. I'll probably take it down to the dealership because it was factory installed and might still be under warranty, but ill for sure look at other shifters, Really appreciate it!
Old 09-07-2016, 01:50 AM   #7
Ultramaroon
not playing cards
Ugh... I'm sorry. It really is an atrocious little device. Ask them about the red loctite. If it comes loose again, seriously, chuck it.
Old 09-07-2016, 01:52 AM   #8
humfrz
Good plan.........
For goodness sake, if you have any more problems ...... please tell us the whole story up front ......
humfrz
Old 09-07-2016, 01:59 AM   #9
humfrz
Bubba says to weld that bolt in place ..........
BTW, what is with the attraction of "short shifters" ...... ??
Why isn't the OEM shifter short enough .. ??
Is it because the young-ens want something like that was on the controller of their video games .. ??
humfrz
Old 09-07-2016, 01:09 PM   #10
Ultramaroon
not playing cards
humfrz
Bubba doesn't realize the mounted adapter doesn't fit through the ball socket.
It's a money maker because it's cool. IMO, the stock throw is already as short as it can be to get enough leverage against the synchros. It's already pretty slow to match at 6500 RPM. Can't rush this gearbox.
I've tried. (You and Tcoat know what I mean.)
Old 07-23-2017, 07:54 PM   #11
WolF_RS
WolF_RS's Avatar
Drives: 2015 Ultramarine Scion FR-S (MT)
Don’t mean to revive an old thread, but what if the bolt and the pin is all tight, using red loctite, but the shifter is still loose? As in a shit show of wiggle room while in neutral, in gears, and having a difficult time trying to get in to reverse?
2015 Ultramarine FRS - OFT Stage 2 E85 - TRD Intake - TRD Strut Bar - Tein Street Flex - Avid.1 AV-20 18x8.5/9.5 Staggered - Muteki Burnt Blue lugs - Toyo T1 Sports F:225/40/18, R: 245/40/18 - TOMEI UEL - TOMEI OP - BERK Straight Pipe - Tomei 80R - Valenti v2 Sequential Clear/Red Tail lights/4th Brake Light - TRD Japan Short Shift - LIKEWISE Deathgrip shift knob - LIKEWISE The Love Button drift knob
WolF_RS is offline   Reply With Quote
Old 07-24-2017, 12:11 AM   #12
Ultramaroon
not playing cards
If you can rotate the shift lever at all it's a definite sign that the adapter came loose. Let's start there.
Stuck Between Gruppe-S or JDL Cojonudo Engine, Exhaust, Transmission 14 06-14-2016 07:33 PM
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 06:28 PM
stuck between brz23 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 03-05-2015 11:01 PM
key keeps getting stuck Covo_86 Issues | Warranty | Recalls / TSB 14 04-21-2014 08:55 AM
