Old 05-17-2018, 02:43 PM   #1
undone14
Drives: 2015 Aquamarine Scion FRS (Auto)
AT - 1st gear gets stuck and hits high RPM's before shifting
Hello Everyone. Long time lurker that finally registered. I have an Automatic 2015 Scion FR-S. I searched the forum and didn't come across this topic (or maybe my search skills suck).
There are times I'm driving and the car is in 1st gear and it doesn't shift into 2nd gear until I either a) release the accelerator a second or two then hit it again or b) it stays in first then shifts after a bit of time. While it's in 1st gear, the RPM's will be higher than normal.
Just checking in to see if anyone else has/had this issue, how to fix it and if there is a TSB for it.
undone14 is offline   Reply With Quote
Old 05-18-2018, 11:05 PM   #2
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
The autos have always been a big interesting. Mind posting up a video showing more in detail? I know driving the car in just plan out "D" is weird. If i do recall the natural shifting patterns of the car made absolutely no sense lol. I just use paddles every time i drive to save a headache.
I'll do my best to pitch my $0.02 with a video. If I had any recommendations just mess around with your accelerator placement. See if it still does it when you lock the pedal at the same spot without moving it forcing the computer to decide the shift rather than letting on harder or softer.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 05-19-2018, 01:06 AM   #3
86TOYO2k17
Drives: 2017 toyota 86
So you are bouncing off rev limiter or hitting fuel cut at 7400rpm in normal D and not in sport mode?
Old 05-19-2018, 01:41 AM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
How high of an RPM are you hitting?
Sometimes my car stays in first gear until about 3500-4000 and then it shifts. This is in "D" mode, no aggressive driving. I have a 2013 FR-S and that's the only thing I experience regarding a gear getting "stuck". Never thought this was an issue?
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
VoltsFRS2013 (05-21-2018)
Old 05-25-2018, 06:32 PM   #5
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
Had issues with my car shifting for the longest time. it would up shift super slow and on down shifts it was very jerky. I just bought a new TCM from ebay and it solved the problem. I think the 13s have an issue
shaynek is offline   Reply With Quote
Old 05-26-2018, 02:32 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Seriously?
I had my TCM software updated and even had a famous post trying to help others get their stuff updated.
When you changed TCMs did it just plug and play? Normally there's a relearn procedure
Old 05-26-2018, 08:16 PM   #7
shaynek
shaynek's Avatar
Originally Posted by FRSBRZGT86FAN View Post
Seriously?
Since I had a 2013 the dealer kept on telling me that there was no update for my car. From reading the forums, i was unsure if the new update would cause issues with my tcm or if it was even compatible. I decided to buy an extra one with the same last 4 digits (b010). It was plug and play and very simple to do
Old 05-27-2018, 11:23 PM   #8
FRSBRZGT86FAN
Interesting, I still have a TCM i bought a long long time ago laying around somewhere could probably sell it to someone
Down shifting into 2nd gear when cold Flame9020 Issues | Warranty | Recalls / TSB 27 12-22-2016 04:24 PM
Gear shifting TexasFRS Scion FR-S / Toyota 86 GT86 General Forum 31 05-11-2016 10:29 PM
Shifting at high RPM - Grinding Magzter Issues | Warranty | Recalls / TSB 16 12-05-2014 01:24 PM
Shifting from 1st-2nd gear... FRSpappa Engine, Exhaust, Transmission 13 05-24-2014 10:06 PM
High RPM Shifting Issue? Rinzler Issues | Warranty | Recalls / TSB 5 05-17-2013 12:30 AM
