Old 09-25-2020, 10:27 AM   #1
R2R
Drives: GT86 TRD CUP
Diff raiser bushes
Seems a common failure in our championship to break the driveshaft (once or twice a season), and while reading online one of the issue may be the wrong angles of the diff.
Seems that diff riser bushes may be a solution, but I'm surprised this is not a very common mod.
Will this stress the prop shaft more? especially since we have an invidia aluminium single piece shaft.
Thanks for the feedback
R2R is offline   Reply With Quote
Old 09-25-2020, 10:43 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
diff riser will help for overlowered cars .. but more for CV bearings, not driveshaft. They will do so by reducing back to lesser angle, and thus load/wear on those bearings.
imho, if driveshafts fail, it might be due different reason, eg. grippy tires paired with too high power forced induction build w/o strengthening apropriately all other drivetrain components ..
The Following User Says Thank You to churchx For This Useful Post:
Joveen (09-25-2020)
Old 09-25-2020, 10:52 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I don't think the yoke on the propshaft would be affected by that slight angle change. This should help the axles, but there are also upgraded axles available if the issue is simply poor tensile strength leading to breaks
The Following User Says Thank You to DarkPira7e For This Useful Post:
Joveen (09-25-2020)
Are aftermarket diff bushes really necessary? Purist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 08-26-2020 10:31 AM
soft diff bushes? notout86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 05-30-2018 11:37 PM
Any idea where these bushes go? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-06-2015 01:12 PM
Valley 86 Fund Raiser for typhoon haiyan lfuentes92 Southern California 0 11-18-2013 02:18 AM
HighSchool Fund Raiser! YYC (Off topic) for a good cause! TheProspect CANADA 2 04-22-2013 12:17 AM
