Old 08-13-2020, 05:13 AM   #1
Purist
Purist's Avatar
Drives: Subaru BRZ
Are aftermarket diff bushes really necessary?
I'm struggling to understand why the diff moving relative to the subframe is that bad.
It won't change the suspension geometry, and how much torque could possibly be lost deflecting bushes?
Will it help prevent axle tramp?
Help me understand.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 08-13-2020, 05:40 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
I guess there are ones not liking slack in bushings and wishing more direct power delivery to wheels and higher response, when modulating accel, instead of it loading first all joints and compressing bushings.
Problem is though, that half-measures of replacing to less compliant just one or few from all of them often reduce that play only partially, rather transfering that shock to other bushings, but replacing all of them may result to unacceptable overall NVH worsening, at least for daily driven car.
It shouldn't cost anything in performance/torque once that initial load/jump has happened. Just that initial bump, reducing a bit response. But "fixing" it will introduce a lot of NVH all the time. Should have no impact on suspension too. So choose your poison, but i'd probably think of reducing compliance in all of tranny/driveline/diff bushings more in some track only car, instead of daily driving one, where whining/rattling all the time transmission might annoy one quick. Or at most, changing to less compliant bushings only where NVH change is reasonable and gains in some other areas outweigh cons of NVH (eg. gearbox bushings to improve shifting).
I'd probably touch diff bushings only if for other purpose, such as changing out to diff riser ones on overlowered car, to reduce wear on CV joints. Not to get rid of that "jump" when putting in gear. Same for suspension bushings .. they do dampen small vibrations and reduce noise noticeably. If you don't need for specific purpose (eg. i needed powerflex eccentric bushings for extra camber, or some use pillowball camberplates for such), or if NVH impact is not that big of (for me eg. subframe mount bushing inserts, or steering rack lockdown), i'd leave stock bushings alone, not upgrade just for sake of upgrading.
The Following 3 Users Say Thank You to churchx For This Useful Post:
DarkPira7e (08-13-2020), Purist (08-13-2020), why? (08-13-2020)
Old 08-13-2020, 06:57 AM   #3
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Help me understand.
It's just the feel of the thing. Even in my stock engine and stock tuned car I can feel it move around and it's annoying. I can't imagine what it feels like in a car with more power, but I can imagine it being annoying.
The Following User Says Thank You to why? For This Useful Post:
Purist (08-13-2020)
Old 08-13-2020, 07:48 AM   #4
Purist
Purist's Avatar
Drives: Subaru BRZ
You can feel the diff move? Maybe I'm not experienced enough as a driver.
My car runs totally catless, UEL headers on E85, and a 4.67 diff. It makes a shit ton of torque compared to stock. I do hillclimbs with MCA Race Primes coilovers and soft compound Yokahama AO50s and I can't feel the diff moving. I can feel the rear end moving and I use it to rotate the car.
The diff moving can not affect the suspension geometry in any way so I don't know what people are feeling, but it's not the diff moving.
I'm not saying there is no issue, but so far no one can offer a valid explanation.
Less More
The Following User Says Thank You to Purist For This Useful Post:
why? (08-14-2020)
Old 08-13-2020, 10:07 AM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
everything is a compromise. subaru uses the bushings they use to minimize NVH. those that change the bushings to something stiffer are willing to deal with more NVH as a tradeoff for a slightly more rigid drivetrain, which presents a few less losses.
on the track? it's probably worth it. on the street? probably not.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
norcalpb (08-13-2020), why? (08-14-2020)
Old 08-13-2020, 10:52 AM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I can say that with doing hillclimb, autocross, and being turbo, I needed to upgrade my subframe bushings and diff mount bushings. The subframe bushings by far made the biggest impression- the rear end stopped feeling like it was floating if I accelerated in a corner.
During hillclimb, I dont notice the rear being bouncy or anything nearly as much as on flat pavement, and I think it's because it's uphill honestly.
Your car may not need them, how many miles? What model year? I don't think it's fair to say that they MUST be done, it's like anything else; replace if necessary. I also got tires with a thicker sidewall because I had insane hopping if the tires were spinning from a launch.
TL;DR- Diff bushings helped stop my skipping/bouncing from hard launches. The car also responds more quickly to throttle input. My bushings were also cracked and dry rotting though..
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
Purist (08-13-2020), soundman98 (08-13-2020), why? (08-14-2020)
Old 08-13-2020, 11:27 AM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It is a "feel" thing. Stiffer drivetrain bushings take windup out of the system. On/off throttle situations the car feel more direct.
Same with suspension bushings. Less deflection, more stable alignment settings through the suspension travel. That part is probably hard to feel for mere mortals. But less deflection makes it easier to feel what the car is doing.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
Ohio Enthusiast (08-13-2020), Purist (08-13-2020), why? (08-14-2020)
Old 08-13-2020, 11:34 AM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
And as NVH tolerance/user preferences/use types/priorities differ from person to person, always worth to rely less on advises from internet, and for all changed parts keep also stock ones and try to avoid irreversible mods. Not all mods/changes can be considered "upgrades" if person is different. Also worth keeping stock ones and not rush with partout for when in future one might sell it off and would wish to revert to stock to up price/broaden possible buyer list. For example - aftermarket exhausts. What might be too mild/quiet for someone, for another one might be too obnoxiously loud & tiring, or not acceptable by significant other/cops/neighbors, so obviously advises that it's ok/not too loud and so on "from internet" should be taken with grain of salt.
The Following 2 Users Say Thank You to churchx For This Useful Post:
Old 08-13-2020, 05:39 PM   #9
Purist
Purist's Avatar
Drives: Subaru BRZ
Thanks mate. Great info. I get awful axle tramp on launch. I'm happy to do mods that solve an identified problem, but most people say 'the feel is better', and knowing how prone modders are to confirmation bias, I'm always skeptical.
Less More
The Following 2 Users Say Thank You to Purist For This Useful Post:
DarkPira7e (08-13-2020), why? (08-14-2020)
Old 08-13-2020, 07:30 PM   #10
Project_1796
Drives: Scion FRS 10 series
Whiteline suspension has a video showing how much the stock subframe bushings move around during acceleration and braking vs with inserts. I have the inserts and chassis bracing so the rear end of my car is solid. You definitely feel all the bumps and crevices in the road.
Project_1796 is offline   Reply With Quote
The Following 3 Users Say Thank You to Project_1796 For This Useful Post:
DarkPira7e (08-14-2020), Purist (08-13-2020), why? (08-14-2020)
Old 08-13-2020, 08:37 PM   #11
Purist
Purist's Avatar
Drives: Subaru BRZ
That video makes me ill. It looks terrible! I can't stand knowing my mounts are flexing like that.
Did it fix any issues such as axle tramp?
Less More
Old 08-13-2020, 09:57 PM   #12
Project_1796
I have the subframe, differential inserts and the diferential out rigger kit and its alot more solid and no wheel hop, I feel the rear has more grip on corners. Nvh is not bothersome for me since they are not solid mounts. It's good for daily use.
The Following 2 Users Say Thank You to Project_1796 For This Useful Post:
Old 08-13-2020, 10:12 PM   #13
Racecomp Engineering
Stiffer suspension bushings do more than just change feel (though that can be nice on it's own). The above video example shows what's happening with the subframe but those types of deflections and shifts can also occur with suspension arms. Result of that is shifting suspension geometry under load. Sometimes that's intentionally designed into a bushing (the voids in the big front control arm bushing), sometimes it's because your bushings are soft from the factory to reduce harshness, and sometimes they're softer than they're supposed to be because they're old and crusty.
See link here for a little extra detail:
https://www.instagram.com/p/CBQUCS9n..._web_copy_link
Driveline bushings have a slightly different job but the whiteline diff inserts do feel really nice.
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
Purist (08-14-2020), why? (08-14-2020)
Old 08-13-2020, 10:37 PM   #14
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
i can second that i feel so much more planted with them installed. with that said does your rear clunk now?
Breadman is offline   Reply With Quote
The Following User Says Thank You to Breadman For This Useful Post:
Purist (08-14-2020)
soft diff bushes? notout86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 05-31-2018 12:37 AM
Any idea where these bushes go? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-06-2015 02:12 PM
Anyone fitted Super-Pro Poly Subframe Bushes?? Nigelr32 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-14-2014 05:11 PM
What are the benefits/costs of an aftermarket diff? dave77 Engine, Exhaust, Transmission 1 03-30-2014 01:43 AM
AVO or Perrin Front LCA bushes? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-02-2013 06:51 PM
