Old 05-07-2018, 01:57 AM   #1
notout86
Drives: GTS 86 auto
soft diff bushes?
something that has bothered since new. I have noticed what I thought was due to the tailshaft flexing winding up and unwinding.... a sort of back and forth surges errr errr errr in second gear on slight acceleration around a sweeping corner.
Something I read made me think it might be due to soft diff bushes? I'd appreciate thoughts people.
Note that our car is auto with torsen diff.
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
Old 05-07-2018, 02:04 AM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Main contributors are the engine mounts and the diff bushings.
notout86 (05-07-2018)
Old 05-07-2018, 06:05 AM   #3
scottman
scottman's Avatar
Drives: 13 mt fr-s
Subframe bushings also. Tightened er' up realnice
scottman is offline   Reply With Quote
The Following User Says Thank You to scottman For This Useful Post:
Old 05-07-2018, 07:47 AM   #4
Turbo86
Drives: '13 Whiteout FR-S
http://www.ft86speedfactory.com/whit...l#.WvA8rIjwbcs
Turbo86 is offline   Reply With Quote
The Following User Says Thank You to Turbo86 For This Useful Post:
Old 05-07-2018, 01:08 PM   #5
wparsons
wparsons's Avatar
I put the whiteline diff bushing inserts in the first summer I had the car, stops a ton of diff movement with minimal increase in noise.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 05-07-2018, 07:38 PM   #6
notout86
Drives: GTS 86 auto
Brilliant thanks Turbo86. Especially the youtube which (as one comment pointed out) shows the diff movement.
To achieve what I want and considering I do not want to introduce too much harshness it looks like just replacing one pair of bushes to start might do the trick, and look like something simple. I'll ask Whiteline.
Old 05-07-2018, 07:49 PM   #7
StraightOuttaCanadaEh
Wes
I think I know exactly what you're talking about as I'm really noticing it now with the summer wheels on. It's like this back and forth pigeon head movement
Instagram: @gt86ws
Old 05-07-2018, 07:56 PM   #8
notout86
Drives: GTS 86 auto
That's it. Except it less like clockwork as it has a bit of a springy feel.
Old 05-07-2018, 08:00 PM   #9
Wes
Yes. God it's annoying. So they're saying trans and diff inserts help? Don't wanna splurge on engine mounts
Instagram: @gt86ws
Old 05-07-2018, 08:33 PM   #10
strat61caster
strat61caster's Avatar
I really liked the subframe bushings, I liked the diff bushings less, ymmv, maybe if I'd done them in the opposite order I'd feel that the diff bushings were better idfk. There's a balance to stiffening it up, a little stiffer seems to sync the car up to itself, too much and you're back to feeling drivetrain lash imho.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
JazzleSAURUS (05-09-2018), new2subaru (05-07-2018), notout86 (05-07-2018)
Old 05-07-2018, 08:50 PM   #11
new2subaru
Weight Weenie
Drives: 15 FR-S
^^This, I'd do the rear subframe inserts/mounts first. See if you want to go any further.
I have both and am going to remove the rear diff carrier insert bushings. I'm going to keep the diff bushings in place. I like it a lot but want to see if I can dial it back just a touch. I can always put them back...
I'm still amazed at how a couple of bushing can make such a difference :/
The Following User Says Thank You to new2subaru For This Useful Post:
Old 05-07-2018, 10:06 PM   #12
notout86
Drives: GTS 86 auto
DRIVETRAIN LASH. That's IT in a nutshell.
The Following User Says Thank You to notout86 For This Useful Post:
strat61caster (05-08-2018)
Old 05-07-2018, 10:14 PM   #13
Pat
Pat's Avatar
Drives: 2023 BRZ
Which did you install first? I did the diff inserts first and really liked them. Then I did the subframe inserts. I also liked them, but the difference was not as noticeable. I wonder if the order matters and, if so, how much.
Old 05-08-2018, 01:14 AM   #14
strat61caster
Subframe first, loved em, no downsides. About a week or three later the diff bushings went in.
Probably any stiffening back there is a positive, but I think you hit diminishing returns as everything gets reinforced and there may be an over-stiff possibility for some people. Eventually I'll try pulling a pair of inserts out of the diff, but there are other things to tinker with in the meantime.
ineedyourdiddly
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 12:07 AM
Any idea where these bushes go? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-06-2015 01:12 PM
Anyone fitted Super-Pro Poly Subframe Bushes?? Nigelr32 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-14-2014 04:11 PM
AVO or Perrin Front LCA bushes? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-02-2013 05:51 PM
I want a soft ride PeterB Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 12-31-2012 11:49 PM
