Old 09-09-2020, 05:03 AM   #1
Flunoir
Drives: stanced
Ayo what da dog doin’
I just tuned my my 2013 Scion FR-S with the Stage 2 E85 tune and drove around nice and carefully for a good 20 miles to let the car re-learn the tune. Anyways, I have a muffler and resonator delete and that’s it. My cat in my front pipe is damaged and I believe that’s why my car work start again. I believe it’s too clogged. I used the oft to pull codes and only got p0118 and p000c. Please help me find out what is wrong exactly with my car or point me in the right direction.
Flunoir is offline   Reply With Quote
Old 09-09-2020, 08:35 AM   #2
Ashikabi
Ashikabi's Avatar
Neither code is cat related. First one is coolant temp and second is cam sensor.
Old 09-09-2020, 04:19 PM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Your car fall under the recall?
Old 09-09-2020, 06:48 PM   #4
Flunoir
Drives: stanced
Thank you, I’m going to have it towed to my shop and they will see
Old 09-09-2020, 06:49 PM   #5
Flunoir
Drives: stanced
What do you mean? It never went in for any recalls, I know that much
Old 09-10-2020, 12:45 AM   #6
x808drifter
LMGTFY
Does your car fall under the Valve spring recall.
That could be the problem also, though unlikely.
Old 09-10-2020, 03:33 AM   #7
dholloway543
Software Hobbiest
Drives: 2015 FRS
Try to start the car and watch the MAF G/S or MAF Volts to see if there is airflow. That is a good indicator of a clogged CAT. Its pretty hard to meltdown a CAT like that unless your doing some risky tuning. Pops and bangs tune.
It could also be your Cam sensor. A bad camshaft position sensor may give you a warning before it completely fails. A failing camshaft position sensor begins losing its ability to quickly transfer data. Mismatched fuel delivery and ignition timing, even if off by a few milliseconds, will cause your vehicle to sputter, accelerate poorly, lack power, stall or even shut off. If the sensor has completely failed the car could just fail to start. I suggest looking at what the car is telling you first and get that sensor replaced
dholloway543 is offline   Reply With Quote
Old 09-10-2020, 10:04 PM   #8
Flunoir
Drives: stanced
Okay so I’ll plug in my oft next time I try to start it and I’ll use the realtime data page, what should I be looking for? And yes, I tuned it before I tuned it for e85 on a pops and bangs tune
Old 09-11-2020, 12:03 AM   #9
dholloway543
Software Hobbiest
Drives: 2015 FRS
If you want to see if your cat is clogged just see when your starting the car check if the maf V (Mass air flow Voltage) goes up. It might only read like 1v or so but if air is moving it should be higher than 0.
Old 01-06-2022, 02:12 PM   #10
Flunoir
Drives: stanced
How do you delete a thread? I want to delete all of these threads from a long time ago.
Old 01-06-2022, 02:14 PM   #11
Flunoir
Drives: stanced
Old 01-06-2022, 02:18 PM   #12
Flunoir
Drives: stanced
Old 01-06-2022, 02:26 PM   #13
soundman98
ProCrastinationConsultant
soundman98's Avatar
you can't. they're forever etched into the history of the internet.
just like life, there's no delete button for reality!
Tcoat (01-07-2022)
Old 01-07-2022, 03:05 AM   #14
Flunoir
Drives: stanced
Corny af but ok
Did donuts, turned off car, turn on car, rough idle, died, no code Lav Engine, Exhaust, Transmission 11 07-13-2024 07:29 PM
Slip Indicator & ABS light turned on during highway driving... Pwolf Issues | Warranty | Recalls / TSB 24 01-15-2018 12:52 PM
CEL came on and turned off on its own? effty_ac Issues | Warranty | Recalls / TSB 13 10-22-2014 08:29 PM
Does the frs/brz still turn heads when driving jon2 Scion FR-S / Toyota 86 GT86 General Forum 100 09-01-2014 12:52 AM
Photoshoot Turned Into This.... Vicious LED FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 48 04-01-2013 09:03 AM
