Old 06-19-2014, 12:49 PM   #1
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
Slip Indicator & ABS light turned on during highway driving...
Figured I'd ask around here...
Last weekend on my way to a meet/drive, the Slip Indicator and ABS lights turned on and stayed on. I ended up getting off the highway and trying a few things, like breaking hard and switching between the traction control modes. After those failed to do anything, I turned off the engine. After restarting the car, the lights stayed off and I didn't notice any issues after that.
The only thing I can maybe attribute to it was I had just gone through the touch-less car wash after filling up at the gas station.
Anyone else notice this before? Should I have the dealer look into it or just wait and see if it happens again?
Pwolf is offline   Reply With Quote
Old 06-19-2014, 07:14 PM   #2
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
If the lights are off, the dealer won't do anything for you. Bring it if when/if they come back on.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 06-20-2014, 12:31 AM   #3
humfrz
Hasn't happened to me ...... but, I think I'd just wait to see if it happens again.
humfrz
Old 02-08-2015, 09:00 AM   #4
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
I had the same issue. It was on on the highway. Once I turned the car off and on. The lights never came back. Is it a loose connection? I dunno. However the abs and traction control seem to work fine.
2022 BRZ WRB 6MT
2018 Camaro ZL1 1LE
vignesh is offline   Reply With Quote
Old 02-08-2015, 11:38 AM   #5
SteveIsBored
Drives: 2013 subaru brz
They won't do anything but if u are curious they can pull the historic codes for u and then they would document unable to duplicate and move on. I wouldn't bring it in either just wait til it comes back
SteveIsBored is offline   Reply With Quote
Old 02-08-2015, 02:06 PM   #6
Pwolf
Pwolf's Avatar
Fortunately this hasn't happened to me since this incident.
Old 02-08-2015, 03:59 PM   #7
I have had it happen twice under the exact same conditions you just described!
I have a carwash pass and with all the salt I run through the touch less wash two or three times a week. It is the type with the high pressure jets that shot up under the car. Twice now the lights have come on when hitting the highway right after a wash and go away after shutting down and restarting. I just put it down as a sensor getting messed up for a minute. As long as they don't stay on or the car doesn't go into limp mode then I don't sweat it.
Old 02-08-2015, 06:57 PM   #8
vignesh
Engineer
vignesh's Avatar
I plan on taking it to the dealership. Should I flash the stock tune. Wondering if the tune is involved with this.
2022 BRZ WRB 6MT
2018 Camaro ZL1 1LE
Old 02-08-2015, 07:11 PM   #9
SteveIsBored
Flashing the stock tune back could delete codes and freeze frame data used in diagnostics. Whether the dealer will run into issues with ur tuning platform while pulling codes etc is question one of the IT guys or software guys to answer or ur tuner
Old 02-08-2015, 07:13 PM   #10
If the tune turns out to be even remotely part of the issue they can deny warranty so yes I would reflash to stock.
But... why take itin if it happened once and went away? Like said already there is nothing they can or will do if it isn't currently happening.
Old 02-08-2015, 07:46 PM   #11
vignesh
Engineer
vignesh's Avatar
Oh well today it happened again. and now it looks like a permanent issue. it happened after i went for a car wash today. So i would need to take it to the dealer.
2022 BRZ WRB 6MT
2018 Camaro ZL1 1LE
Old 02-08-2015, 08:06 PM   #12
Yep! That is a whole new story!
Old 02-08-2015, 08:06 PM   #13
Koa
absolutely flash back to the stock rom before taking it into the dealer.. hands down.
Old 02-08-2015, 08:30 PM   #14
vignesh
Engineer
vignesh's Avatar
Well i am wondering if i put the stock tune on the lights may not appear. i would like for the lights to be on when i do go to the dealership.
2022 BRZ WRB 6MT
2018 Camaro ZL1 1LE
Engine Light On (malfunction indicator lamp) polarstorm Engine, Exhaust, Transmission 0 06-01-2013 11:14 AM
CEL and Slip Light Gums AUSTRALIA 10 01-15-2013 08:42 PM
CEL and slip light? Rob_g Issues | Warranty | Recalls / TSB 2 10-03-2012 04:57 PM
Slip Indicator Light erom BRZ First-Gen (2012+) — General Topics 17 06-10-2012 10:17 PM
Setting rev indicator light video ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 3 06-09-2012 10:58 PM
