Old 09-07-2020, 12:31 PM   #1
SmoothIsSlow
Silver metal shavings in transmission fluid
Hi all,
I just did my first transmission fluid at 25k mile yesterday. The drain plug had some bright silver metallic shavings/flakes, no larger than a few millimeters, in addition to some black sludge, is this normal for a factory fill? The transmission felt fine but feels smoother even now with a new fill of motul 300.
I have a lot of mechanical sympathy but track the car, which is why I changed the fluids at all.
SmoothIsSlow is offline   Reply With Quote
Old 09-07-2020, 01:38 PM   #2
ls1ac
ls1ac's Avatar
A few mm is huge in a trans.
A metallic coloration to the fluid is normal.
Save the partials on a clean cloth and take a picture.
Old 09-07-2020, 01:53 PM   #3
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
I would think some shavings are normal during the break-in period but I'm not too sure about the sludge. If the transmission feels fine I say you shouldn't worry about it too much.
SUSPECT_BRZ is offline   Reply With Quote
Old 09-07-2020, 01:58 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
Old 09-07-2020, 03:50 PM   #5
SmoothIsSlow
Thanks for the response. I sillily did not think much of it at the time and did not take pictures. Imagine if you snip the very ends of a paper staple off. There was maybe half a dozen of such chunks at 1mm or 2mm.
I don't suppose Subaru will give me a new tranmission based on this information alone...
Old 09-09-2020, 12:40 AM   #6
jflogerzi
jflogerzi's Avatar
Nope they want proof...
2013 Series 10 FRS #553
Old 09-09-2020, 02:04 AM   #7
humfrz
Why would they give you another transmission if their is nothing wrong with the one you have?
What you are seeing is just a few rough edges ground off of a few gears.
See how smooth it runs now -
Seriously, I wouldn't worry about.
SmoothIsSlow (09-09-2020)
Old 09-09-2020, 06:31 AM   #8
SmoothIsSlow
Humfrz, stopping nerds from tweaking on miata dot net since 2006
The Following 3 Users Say Thank You to SmoothIsSlow For This Useful Post:
ElijahF (09-09-2020), humfrz (09-09-2020), soundman98 (09-09-2020)
transmission fluid John27 Scion FR-S / Toyota 86 GT86 General Forum 7 04-25-2017 09:14 PM
Metal shavings in oil after change. Raven604 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 23 09-10-2016 06:03 PM
MT Transmission Fluid mstoochn Scion FR-S / Toyota 86 GT86 General Forum 1 06-14-2015 10:06 PM
AT fluid metal shaving? chenshuo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-24-2013 09:28 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 11:45 PM
