Old 08-31-2020, 12:34 AM   #1
JaeMHC
Drives: FRS
Squishy brake pedal after bleeding and changing fluid
I was driving when my brake pedal all of a sudden became very squishy.It happened a few days before I was scheduled to take it to my mechanic to change out my rotors and pads. I told him about the squishy pedal and he said he'd bleed the brakes. He bled them and then told me to take it for a drive and the pedal was still squishy so he told me he would bleed them again. I picked up the car the next day and the pedal is still squishy but not as squishy - it has pressure when you step on it and then it slowly depresses until its all the way pushed in. We think it might be the clutch master cylinder that is faulty but has anyone else ran into this problem?
Its a 2013 FRS with 210,000 km
JaeMHC is offline   Reply With Quote
Old 08-31-2020, 02:07 AM   #2
humfrz
In case you missed this on your other thread -
No, but I would suspect the master or slave cylinder to be worn out, if, of course, the fluid is not being pushed out (leaking).
They are relatively inexpensive and easy to replace.
But, if you are going to have the pads and rotors replaced, why not wait and do it all at once.
Old 09-05-2020, 08:35 PM   #3
wparsons
wparsons's Avatar
Typically if the pedal feels reasonably solid, then goes soft while holding pressure on it you've got a problem with the master cylinder. You should be able to hold pressure on the pedal for 30 seconds without it collapsing to the floor. There's no way it's the clutch master if you're having brake issues though, it'll be the brake master.
flickr
Squishy brake pedal after bleeding and changing fluid JaeMHC Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-03-2020 08:38 PM
What brake fluid do you use when bleeding/flushing the clutch? MINOCIN Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 08-24-2020 12:07 PM
Using higher quality brake fluid vs using cheap but changing more often ayau Tracking / Autocross / HPDE / Drifting 41 06-14-2015 01:20 PM
Just changed pads and fluid; brake pedal has more "dead space" ryoma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-13-2015 02:56 AM
Properly flushing/bleeding radiator fluid? swift996 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-30-2014 02:50 PM
