Old 05-09-2015, 04:40 AM   #1
ryoma
ryoma's Avatar
Just changed pads and fluid; brake pedal has more "dead space"
so I just changed my pads from OEM to Winmax W5 and fluid from OEM to Torque RT700 for an upcoming track day. As I was bedding in the pads, I noticed that I need to push my brake pedal further in, about halfway, before I feel the brakes start biting. Is this due to the RT700 fluid? or do I still have air in my lines? I bled each caliper twice and saw no air bubbles and made sure to flush out all of the old fluid as well. I used up 750ml of brake fluid so I assume I flushed out the entire system (I heard the lines only hold 0.5L).
I also changed out the rear lines to stainless steel, but couldn't get the hard line nut off of the front passenger side, so I left both front lines the OEM line. going to bring it to a shop and have them finish it off. could this be the reason why as well?
the brakes work great though, but since there's that dead space of about half the pedal travel, I need to push in the pedal more to use a little bit of brake. I just want to make sure that this is not me failing on my part and if it is normal lol
Old 05-09-2015, 04:46 AM   #2
CSG David
CSG David's Avatar
You have air in the hydraulic system. You need to rebleed your brake fluid and make sure the air is out of the system.
Old 05-09-2015, 04:57 AM   #3
ryoma
ryoma's Avatar
alright, I'll bleed it again tomorrow. maybe there was an air bubble trapped in the middle of the lines.
Old 05-09-2015, 02:39 PM   #4
CSG David
CSG David's Avatar
Very likely since you replaced the lines in the rear. It's a PITA, but the best way to get all the bubbles out of the system is to flush once. Drive around a little bit to use the brakes and then put back on jackstands...rebleed.
Old 05-09-2015, 05:02 PM   #5
ryoma
ryoma's Avatar
just rebled the brakes and it feels a little bit better, but still notice that dead spot. guess that air bubble is really stuck in there. I'm out of fluid now so I'll just have the shop finish it off on Monday.
Old 05-10-2015, 09:10 AM   #6
wparsons
wparsons's Avatar
With better pads and fluid you should feel a massive difference in the pedal, but towards the hard/firm side, not softer or more of a dead spot. Better pads aren't as compressible as stock, so even if the cold bite isn't the same the pedal will feel firmer.
flickr
Old 05-10-2015, 10:40 AM   #7
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Even with oem fluid and pads, the pedal should be firm when there is no air in the system.
Old 05-12-2015, 08:17 PM   #8
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Update with how you like the w5s when you get the air out.
Old 05-13-2015, 01:19 AM   #9
CSG David
CSG David's Avatar
Pedal should be rock solid when you attempt to pump it when the car is off and no key in the ignition. If it's not, then you have a problem...
Old 05-13-2015, 01:30 AM   #10
ryoma
ryoma's Avatar
I'm going out again tonight to bed them in, just waiting for it to be a bit later so there's no one on the road. the air is all out and feels solid when pushing down on the pedal. I didn't bed them in right the first time so I'm redoing it. went 10 times from 50 to 12 then twice from 70 to 50, then once from 70 to 12. then after reading the slip of paper again, it says to do each set (50-12, 70-50, 70-12) 7-9 times, if I'm reading it right lol. I just see some streaks of pad residue on the rotors and the paper says you're supposed to see an even layer of it. so I guess I'm just gonna keep braking until it's all over the rotor.
Old 05-13-2015, 02:25 AM   #11
The speeds aren't as important as getting a good transfer layer. If you're seeing streaks, you're overdoing it, and cooking the pad (and MELTING a layer of pad onto the rotor).
If you smell pads, you need to back off and keep rolling for a bit to let the entire system cool down.
Old 05-13-2015, 02:56 AM   #12
ryoma
ryoma's Avatar
alright, last time I bed it in, I definitely smelled the pads. I'll take it slow tonight and get some solid braking in.
EDIT: after driving it around tonight, the streaks are gone. There is a light film, but it is also in a streak. not sure if you can see it in the pictures. does that mean the pad is uneven, and I need to wear it down more to get an even film across the rotor? I do notice that the brakes still squeal though, so I'm assuming I didn't do enough braking.
"dEAD CLICKS" ON TEIN ST FLEX Khánh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 03-10-2019 02:36 PM
Soft pedal / dead zone after new pads juliog Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 10-28-2018 06:15 PM
Who's tired of the "Pedal Dance" and wants to be in real control of their car? FT-86 SpeedFactory Tracking / Autocross / HPDE / Drifting 61 10-01-2015 07:44 PM
Additional "pedal dance" testing. CSG Mike Tracking / Autocross / HPDE / Drifting 55 08-27-2013 03:02 AM
Has "New Posts" changed? Dadhawk Site Announcements / Questions / Issues 12 05-20-2012 10:18 AM
