Old 08-20-2020, 02:32 AM   #1
Deemsim
Drives: 2013 Gt86
Noise when turn at low speeds
Hi there,
Was just hoping to get some ideas from people before having a look under my 86 myself.
When turning at low speeds, especially at a stop. The front end has a screeching sound, it sounds like ive run over some tree branches. I plan to inspect the ball joints of the lower control arm and outer tie rod end but i was wondering if theres anywhere else i should be looking?
Any feedback would be awesome.
Cheers
Edit: Here is a video of the noise, perhaps i over exaggerated the description of the noise haha. You can hear it better in the second video
Deemsim is offline   Reply With Quote
Old 08-20-2020, 02:37 AM   #2
Turdinator
Señor Member
Turdinator's Avatar
Firstly, welcome to the forums. If you post a video with the sound and you will probably get some responses but also, any suspension mods we should know about?
1974 TA22 Celica
2013 86 GT
Old 08-20-2020, 02:42 AM   #3
Deemsim
Drives: 2013 Gt86
Thanks. No suspension mods have been done to it yet. I will try a post a video soon, if it helps the noise is only on the left (passenger) side.
Old 08-20-2020, 01:52 PM   #4
norcalpb
norcalpb's Avatar
Seems like all our 2013s are starting to have our front suspensions fall apart lol.
Old 08-20-2020, 01:58 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
Screeching tree branches, now that's a video I want to see.. Sounds like a horror movie..
Old 08-20-2020, 09:02 PM   #6
Deemsim
Drives: 2013 Gt86
Haha it was the only the only thing i could think of when i heard it
Old 09-01-2020, 03:12 PM   #7
jeconti
Drives: '13 BRZ Limited
So did you find out the culprit? I also have a 2013 and it is starting to make the same exact sounds. No suspension mods. Just a stock 2013 BRZ Limited.
jeconti is offline   Reply With Quote
Old 09-01-2020, 03:15 PM   #8
JD001
JD001's Avatar
Drives: Subaru BRZ
I think the problem is the word "stock". You've got an itch to switch and just looking for the right excuse... Any bump, noise or screeching branch is enough to get the twitch twitching..
The Following User Says Thank You to JD001 For This Useful Post:
soundman98 (09-01-2020)
Old 09-01-2020, 03:37 PM   #9
jeconti
I mean, I have been generally following the rule of thumb of: failed parts get replaced with upgrades. Nothing aggressive, but I am at a crossroads. I don't know what part needs to be replaced/upgraded lol.
Old 09-01-2020, 03:40 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
Tyres, bushes, dampers and springs are consumables and have a limited life. So get changing...
Old 09-01-2020, 03:48 PM   #11
jeconti
Managed to get a good video. Can hear it really well.
The tires are new, only a few months old. Less than 5k on them.
Suspension is stock though. Sound like springs to you?
Old 09-01-2020, 04:39 PM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, by chance, it's not EPS coupler that's noisy?
Old 09-06-2020, 07:08 AM   #13
Deemsim
Drives: 2013 Gt86
I partially found the source of the noise, upon visual inspection i could see my tie rod ends were worn. It had a lot of play and the joint was fill with grit. It fixed most of the noises that i was having, theres still a slight creaking noise. I suspect its the inner tie rod this time, don't know why i didnt inspect that too lol. Will have a closer look another time.
The Following User Says Thank You to Deemsim For This Useful Post:
norcalpb (09-06-2020)
Old 09-06-2020, 07:26 AM   #14
JD001
JD001's Avatar
Drives: Subaru BRZ
Glad you've got a handle on your noisey companions.. upgrade the bushes..
weird noise when using right turn signal (blinker) Zoik Electronics | Audio | NAV | Infotainment 0 08-29-2016 02:37 PM
Turn signal stalk making weird high pitched noise. FRS-Learner Issues | Warranty | Recalls / TSB 6 11-07-2015 08:54 PM
Clicking noise only when i turn on the lights Srekal006 Cosmetic Modification (Interior/Exterior/Lighting) 11 07-30-2015 07:59 AM
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 10:11 AM
Post you speeds for fun... seven Off-Topic Lounge [WARNING: NO POLITICS] 48 01-27-2013 07:37 PM
