Old 11-07-2015, 01:32 PM   #1
FRS-Learner
FRS-Learner's Avatar
Drives: 2014 Whiteout FR-S MT
Turn signal stalk making weird high pitched noise.
Hey guys, I tried searching for this problem but came up blank. Car is 2014 Fr-s with 17k miles. No mods that would affect the turn signal stalk.
Recently whenever I turn the turn signal stalk, either to turn right or to turn left, it emanates this weird high pitched sound. It sounds exactly like a defibrillator that's charging up. Like the ones in movies where they try to "jump start" people whose heart stopped working with electricity??? Whenever I turn the stalk this weird noise comes from it and sounds EXACTLY like a defibrillator. I only clean the stalk from time to time with a microfiber cloth. But this started happening randomly and not after I had cleaned it. I have no idea what't going on and I do not think this sound is good in the long run. Plus it would be hard to reproduce the sound at the dealer because this sound is does not always happen, which makes me wonder a lot about what it could be.
All replies would be helpful, thanks.
FRS-Learner is offline   Reply With Quote
Old 11-07-2015, 04:37 PM   #2
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Is it blinking really fast?
Sent from my SM-N920T using Tapatalk
SoCal80six is offline   Reply With Quote
Old 11-07-2015, 05:54 PM   #3
FRS-Learner
No, no of the lights blink fast and the dash arrow does not blink fast. The only occurrence is the really weird sound. Sounds like something electrical from the turn signal stalk.
Old 11-07-2015, 05:57 PM   #4
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Weird might be an electrical issue. Had my front left parking light go out and my rear left blinker started blinking super fast ahah.
Old 11-07-2015, 06:43 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
The whining you hear on TV is usually the sound of a capacitor charging up to store current to be discharged from the defibrillator. In our cars the turn signals use an electromechanical relay which is also where the "click noise" comes from as the turn signals go on and off. Its under the steering wheel and above the foot well and you can literally grab at it and pull it out, in fact for people that do an LED swap this is a necessary evil so the LEDs turn signals blink at the correct rate. I am sort sure where the charging noise is coming from or if it's just some sort of coil whine, but I'm pretty positive it is from both the capacitors resonating at some weird frequency:
This is a good image of what's inside a flasher relay, not ours mind you, ours are sort of beige in color on the outside and has 8 pins not 2 prongs:
The arrow points to the capacitor
OR It could be from within the turn signal stalk
To fix this if the whining is a serious annoyance and if it's from the relay you're just gonna need to buy a new stock LED relay:http://www.ebay.com/itm/2013-Scion-F...NSjoX6&vxp=mtr
Honestly I'd order it just in case when the relay might fail, because none of our cars do the charge up whine it might mean yours will fail prematurely.
Old 11-07-2015, 07:44 PM   #6
FRS-Learner
This is a good image of what's inside a flasher relay, not ours mind you, ours are sort of beige in color on the outside:
Thanks, I just have one question. Can I pull this relay out and test it by any chance?
Old 11-07-2015, 08:54 PM   #7
FRSBRZGT86FAN
It's super easy,anyone like me or others that do LED swaps have had to do it, it's right under the steering wheel:
Skip to 0:50
[ame="https://www.youtube.com/watch?v=AAEz3YC8SCA"]FR-S / BRZ Fix Turn LED Hyperblink with Flasher - YouTube[/ame]
Turn signal stalk with foglight switch P3tras Interior Parts (Incl. Lighting) 8 11-02-2015 09:02 PM
WTB: turn signal stalk with AUTO, front fog 1GiantTurtle Want-To-Buy Requests 0 10-14-2014 10:03 PM
FS: OEM Turn Signal Stalk Zagmeister Exterior Parts (Aero, Lighting, Etc.) 4 07-05-2014 10:08 AM
WTB: turn signal stalk w/ fog alderaan34 Want-To-Buy Requests 0 03-28-2014 10:13 PM
High Pitched Noise, Engine Off TheLaughingMan Issues | Warranty | Recalls / TSB 10 01-04-2014 05:25 PM
