Drives: 18 brz
p2270 after header install
17 brz throwing a p 2270 after a header install this weekend, running OFT's stage 2+ tune. The rear 02 port did have a 90 degree adapter. Should I try replacing the sensor, removing the adapter or clearing the code to see if it comes back? Open to suggestions
SCBYD0
Drives: 18 BRZ (WRB)
Remove the spacer and clear the code to see if it comes back. It's possible it's leaking because of it. There is no reason to run a spacer since you have a tune nor should there be a reason to replace the sensor already.
04 Scion xA > 13 FR-S stg 2 UEL E85 > 16 WRX stg 1.5 > 15 Audi S3 > 18 BRZ Limited UEL E85
| P2270 | j_ros94 | Engine, Exhaust, Transmission | 3 | 05-21-2019 08:29 PM |
| P2270 | j_ros94 | Issues | Warranty | Recalls / TSB | 5 | 05-21-2019 06:23 PM |
| ECU Code P2270? | Razzamatazz | Issues | Warranty | Recalls / TSB | 3 | 09-10-2018 05:20 AM |
| BRZ header install | Highweigh | BRZ First-Gen (2012+) — General Topics | 4 | 09-23-2016 10:55 AM |
| UEL Header install | Romiikr | Engine, Exhaust, Transmission | 7 | 12-21-2015 01:31 PM |
