Old 05-21-2019, 02:37 PM   #1
j_ros94
Drives: 2017 Subaru BRZ
P2270
My car wont be under warranty as i have a turbo on it but should i clear the code or have someone take a look? Can anyone let me know if this code is safe to drive?
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 05-21-2019, 03:20 PM   #2
aemravan
Its a lean code for bank 1.. are you running a wideband AFR gauge? If so, what are your AFR's looking like? How long has it been boosted for?
If you have a wideband AFR gauge you know what your engine is doing fuel wise so I would find it OK to drive until you fix the issue (possibly a failed sensor?) if you don't have an AFR gauge then its hard to say if you really have a bed sensor or if its really running lean on that bank. A lean turbo motor is not a happy motor
aemravan is offline   Reply With Quote
Old 05-21-2019, 03:23 PM   #3
j_ros94
Had it boosted for about 2 weeks and unfortunately i dont have an afr gauge. Could I possibly use the oft to run a real time diag on it?
If it does have the a/f reading what would be the optimal ratio?
Old 05-21-2019, 03:37 PM   #4
aemravan
Well if your car is throwing a lean code I would be very cautious to read the AFR signal that the sensor is sending... because again, this could be a faulty sensor that failed during your tuning period/running too rich.
I'm not sure how lean these motor can go being so high compression, but from the supra world, under heavy load you want to stay around 10.3-10.5 to be on the safe side. For cruising/idling you want to be near stoich. levels (14.3-15ish level) if your car is, for instance, reading something like 15-16 afr it may be running a bit lean but I'm new to this specific motor/turbo combination so unfortunately can't be of much help.
are you running larger injectors/custom tune or what?
Old 05-21-2019, 05:49 PM   #5
j_ros94
Yes i am running larger injectors and have an ecutek tune
Old 05-21-2019, 07:23 PM   #6
j_ros94
I plugged my oft and on idle the afr is between 14-15
P2270 j_ros94 Engine, Exhaust, Transmission 3 05-21-2019 09:29 PM
ECU Code P2270? Razzamatazz Issues | Warranty | Recalls / TSB 3 09-10-2018 06:20 AM
