Old 09-23-2016, 10:42 AM   #1
Highweigh
Drives: '13 Subaru BRZ Limited
BRZ header install
I just installed some UEL headers on my BRZ yesterday and I didn't even think to check what the header nuts are supposed to be torqued to.
I'm a little worried that I may have over tightened them. Drove the car for about 50 miles now everything seems fine.
Stock spec is 27 ft lbs I believe? Hard to imagine what 27 ft lbs feels like with a regular ratchet. Should I get a torque wrench and loosen and re-tighten the nuts?
Thanks guys
Highweigh is offline   Reply With Quote
Old 09-23-2016, 10:44 AM   #2
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
You should be fine, I wouldn't worry too much about hitting exactly 27 lb-ft. Did you use new bronze nuts?
GSpeed is offline   Reply With Quote
Old 09-23-2016, 10:46 AM   #3
Highweigh
I did not. I used the nuts from the previous exhaust manifold.
Old 09-23-2016, 10:50 AM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I've installed dozens of exhaust on various cars, hand tight was good enough.
8RZ is offline   Reply With Quote
Old 09-23-2016, 10:55 AM   #5
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Not worth going back and re-doing, but occasionally used nuts will come loose. Just keep an eye on it and listen for exhaust leaks.
Best Shop in the GTA for a Header Install? Bzives CANADA 22 05-12-2016 02:07 PM
UEL Header install Romiikr Engine, Exhaust, Transmission 7 12-21-2015 01:31 PM
no cel after catless header install vestal52 Engine, Exhaust, Transmission 14 05-22-2014 02:21 AM
Header install in Toronto CreinCrein CANADA 14 01-26-2014 10:03 PM
Gas mileage goes up after header install Scalzo Engine, Exhaust, Transmission 7 05-24-2013 11:28 PM
