Old 06-22-2020, 08:29 PM   #1
trinidadj
Drives: '16 FRS-MT Ablaze Red
Alignment and Steering Sensitivity
I'm having an issue where my steering input feels overly sensitive. The most recent changes to my car are new rear tires(Installed on June 13), the front tires are at 4/32 thread. The tires are pilot sport 4s. All of my suspension components appear to be okay. Prior to the new rear tires everything was fine. Here is a copy of my alignment(completed on May 20) when all tires were at 5/32 thread.
It is more noticeable at highway speeds for instance if I add steering input left or right the car feel like it wants to pull really had in that direction.
Do I need to dial back some of the toe?
trinidadj is offline   Reply With Quote
Old 06-22-2020, 09:05 PM   #2
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
If the tires triggered the change, why would you not look at the tires first to solve the issue?
Why keep the dead fronts with new rears? 3/32 is meant for the trash heap, you're keeping them on the car because?
Also, toe in inches? Smh.
Old 06-22-2020, 09:30 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
0.19 inches total rear toe (0.44 degrees!) is IMO too much. People always say it "adds stability" but in my experience more than *just a smidge* causes the rear to be unstable when you want the car to go straight, and gives understeer when you want it to turn in. And kills tire life. Sucks for *everything*.
Have them knock rear toe-in down to about 0.1 *degrees* total, or 0.04 inches total.
Also worth noting that brand new rear tires at full tread depth will have noticeably more tread squirm, which could be part of what you're feeling.
Old 06-22-2020, 09:38 PM   #4
trinidadj
The symptoms your describing are pretty much whats happening.
"causes the rear to be unstable when you want the car to go straight, and gives understeer when you want it to turn in"
I think its probably the alignment as well. The alignment guy said this would be a good set up even though I told him to I really wanted to go with -2.5 front camber, 0 front toe and -2.0 rear camber, 1/16" rear toe in. Guess its time find a different shop lol.
Old 06-22-2020, 10:16 PM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
Some are so convinced that "more rear toe => greater stability!" they really try to force in on ya... I'm sure if you insist the same shop will put it where you want.
Honestly you could go with zero even. But IMO 0.1 degrees is a good place to be.
Old 06-22-2020, 10:18 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
i thought we solved this in the other thread... you need new front tires.
Old 06-23-2020, 01:07 AM   #7
humfrz
That, and like said, 2 new front tires -
Old 06-23-2020, 10:18 AM   #8
trinidadj
Bet new tires are coming thursday, I'll report back on this. Also going to get the toe knocked back down.
Old 06-23-2020, 02:27 PM   #9
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Total toe in the front is out of range too.
nico_rsx is offline   Reply With Quote
Old 06-23-2020, 03:16 PM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yeah, that's a lot of front toe=in, 0.1 inch is 0.23 degrees. I run zero...
Old 06-23-2020, 11:42 PM   #11
Decep
Drives: 2013 FR-S Series 10
This alignment shop sucks...did you give them any specs or just let them do their thing?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Heavy Steering After Alignment / Specs? Pizzachicken Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 06-14-2019 09:38 AM
Steering wheel alignment question Keenercarguy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 03-22-2017 07:07 PM
Alignment of steering wheel changes.... DrDuquette Issues | Warranty | Recalls / TSB 7 09-14-2015 11:51 AM
Which shop can zero the steering angle sensor and yaw sensors after alignment? krayzie CANADA 5 09-09-2015 06:28 PM
Crook steering after getting alignment Maverickgear Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 08-29-2014 03:45 AM
