Old 08-28-2014, 01:18 PM   #1
Maverickgear
Drives: World Rally Blue BRZ
Crook steering after getting alignment
Hi guys, I have a mystery on my hands and I was hoping maybe you guys could help me shed some light on it.
I recently got a set of coilovers, got them installed, and did my alignment. Found it had crooked steering even though I had it aligned. So I assumed they might not have centered the steering wheel properly while doing the alignment, however, they told me they did and if I wanted to get up the alignment rack again I had to pay another fee for it.
So I left and headed for my frequent alignment shop. I went up the rack and they locked down the steering wheel. But we found that the toe was at neutral position already.
But the car is veering to the right when the steering wheel is straight. What gives?
I had to do something like this, http://www.e90post.com/forums/showthread.php?t=749585 , to get the steering wheel centered. Second question would be, is it safe doing this to get the car to go in a straight line? What's in the article is adding more toe on one side and removing some from the other to "compensate" while keeping total toe the same. I believe after doing such a fix, the static toe would be all over the place.
Eventually I went back to stock and everything was dead center after alignment. I would like to find out if this is a problem with the coils? Or just an alignment issue. As if it's the coils problem, I can confidently push for a warranty or refund.
TL;DR after installing and aligning new coilovers, had crooked steering. When returned back to stock, was back to normal.
Maverickgear is offline   Reply With Quote
Old 08-28-2014, 01:25 PM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
This happened to me as well after getting an alignment after a lowering spring install.
I've just been living with it, as the car still tracks perfectly straight and doesn't pull in any direction - it definitely feels aligned.
It's just a visual thing with the steering wheel being slightly off center when driving straight. It's a somewhat annoying and nagging thing.
Originally Posted by humfrz
I'm old and lazy
Old 08-28-2014, 01:31 PM   #3
wparsons
wparsons's Avatar
Is there camber adjustment in your coilovers (slotted hole or camber plates)? Was camber even L/R? If camber is off a bit then it'll pull as well.
flickr
Old 08-28-2014, 01:33 PM   #4
cnk
Drives: '13 DGM BRZ Limited
Roads have a natural slope to the right for water drainage. Are you sure you're not just noticing that now because it's after a mod? Some alignment shops will account for the road crown.
Sent from my SAMSUNG-SM-N900A using Tapatalk
cnk is offline   Reply With Quote
Old 08-28-2014, 01:34 PM   #5
Maverickgear
Yeah, camber and toe was even on both sides. Front and rear axles as well. The only thing left unmeasured was the caster, but I doubt casters would be affected Ya?
I see.. Yes it is very annoying and it just won't do with my OCD for straight steering :p
I wonder what's the cause of it though.
Old 08-28-2014, 01:38 PM   #6
Maverickgear
I have heard alot of techs and mechanics giving me that reason. But the angle of the cooked steering is just too much for me to accept it as a measure to account for the crowns on the road.
When I center the wheel, I will have to immediately correct it else I will be in the other lane within the next second. The veer is quite severe in my opinion.
Old 08-28-2014, 01:55 PM   #7
df.dima
Drives: FR-S and Mazda 3 Sky
My steering wheel was off and took a whole 5 minutes to align it straight. Find someone who knows what they do. Don't accept it as is.
df.dima is offline   Reply With Quote
Old 08-28-2014, 01:56 PM   #8
Maverickgear
Did u check your toe alignment after getting it fixed?
Old 08-28-2014, 11:11 PM   #9
MyEvilMonkeys
Drives: 2013 Scion FRS
Take it back.
FA500 Coils/Swift/Radial Upgd, Cusco R.LCA, SPC R.Toe Arms, TqSol. R.SubFrame Bushings, MTEC Shift Springs, Perrin Shift Bushing/Trans Mount, Greddy SP Exhaust & Intake, RPF1 18x9.5 +38, 255/35-18 SDrives, Raceseng Ashiko Knob/Lockout
MyEvilMonkeys is offline   Reply With Quote
Old 08-28-2014, 11:31 PM   #10
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by MyEvilMonkeys View Post
Take it back.
Originally Posted by Maverickgear View Post
...I recently got a set of coilovers, got them installed, and did my alignment. Found it had crooked steering even though I had it aligned. So I assumed they might not have centered the steering wheel properly while doing the alignment, however, they told me they did and if I wanted to get up the alignment rack again I had to pay another fee for it...
1974 TA22 Celica
2013 86 GT
Old 08-28-2014, 11:46 PM   #11
Maverickgear
Take it back.
I would gladly love to if they'd stop giving me a run around and tons of excuses on how it's normal for a coilover set to do that
Old 08-28-2014, 11:49 PM   #12
pantdino
Drives: Firestorm 2013 FR-S
toe, camber, and caster are all standard alignment variables
I haven't had to have many cars aligned, but the tech usually drives the car a bit to see if the wheel is centered and the car drives straight
Pay another fee for what? If they couldn't get it right the first time, what makes them think they can get it right this time?
Take it somewhere else and file a complaint with your state's consumer protection agency or auto repair board or whatever. The tech is incompetent and wants you to keep paying him while he learns.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 08-29-2014, 12:19 AM   #13
pitstops
Drives: SC RB FRS
if your tires are non-directional swap the front tires left to right. if your car was pulling to the right and now its pulling to the left after the swap you have tire pull.
if your tires are directional you would need them dismounted and swapped.
uneven caster can make it pull. it will pull to the side with least caster. when i do alignments i usually put less caster on the driverside to compensate for road pull.
the directions on e90post is exactly what i do after a test drive if the steering wheel is off center. no problem in doing that, have double checked it back on the machine.
pitstops is offline   Reply With Quote
Old 08-29-2014, 12:27 AM   #14
Poodles
Drives: 2015 Series.Blue
This is straight up bullshit. I'd be getting a refund and going elsewhere as the work is not done correctly and services where not rendered.
The Following User Says Thank You to Poodles For This Useful Post:
Hanakuso (08-29-2014)
DIY Alignment FRSFirestorm DIY (Do-It-Yourself) Guides 41 01-31-2020 07:06 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
Steering Feel Question Concerning Tic Solid Steering Bushings brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 10-31-2013 04:52 PM
Alignment in GTA? f0rge CANADA 13 09-06-2013 12:17 PM
where to get alignment? FML Hawaii 2 08-08-2012 01:36 AM
