Old 03-15-2017, 11:50 AM   #1
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Question Steering wheel alignment question
Does anyone know how to adjust the steering wheel position? I just got a good alignment but the wheel is slightly turned to the right when traveling straight... I can't go back to the shop while they're open before I have to make a long trip, but I have jack stands and a variety of tools. Basically I'm also asking if changing the steering wheel position will impact the alignment I just got.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 03-15-2017, 12:54 PM   #2
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
Yes, you'll mess up your alignment if you try to adjust it yourself. Take it back. The shop messed up by not centering the wheel before performing an alignment. Sloppy work.
Read my writing about the BRZ on my website.
PandaBRZ is offline   Reply With Quote
Old 03-15-2017, 01:46 PM   #3
B T
sloppy work indeed
B T is offline   Reply With Quote
Old 03-15-2017, 03:08 PM   #4
redlined600
redlined600's Avatar
Drives: Fr-s
Assuming there isn't any toe angle the steering wheel center is somewhat irrelevant* in terms of actual alignment. That said, if they were sloppy with the steering wheels angle it's quite conceivable that the front toe or thrust isn't perfect either and that's what would concern me more.
You should take it back and have them fix it.
*I'm guessing that at some point the car's stability system would object
Old 03-15-2017, 03:19 PM   #5
Keenercarguy
Mountain Runner
Yeah the only issue is I have absolutely no availability to take it back before making a couple hundred mile road trip. Looks like I'll just be driving on it then, bummer. This is the push I needed to just install the HVT Camber plates that I have had sitting around.
Old 03-15-2017, 03:20 PM   #6
Keenercarguy
Mountain Runner
Yeah sloppy indeed, sad because they've done a bunch of AutoX alignments for me over the past few years and none have ever been a problem until now
Old 03-16-2017, 05:50 AM   #7
tyler_win_photo
tyler_win_photo's Avatar
I would have asked them to redo the alignment the moment I noticed the steering wheel wasn't centered.
tyler_win_photo is offline   Reply With Quote
Old 03-16-2017, 10:58 AM   #8
jcw99
Drives: swp mt '14 brz premium
a crooked steering wheel often results from doing a 2-wheel alignment rather than a 4-wheel alignment
jcw99 is offline   Reply With Quote
Old 03-16-2017, 03:15 PM   #9
wparsons
wparsons's Avatar
If they didn't re-calibrate the VSC system having the wheel off center will also cause the VSC system to have an un-needed intervention every now and then.
flickr
Old 03-16-2017, 03:27 PM   #10
KnightRyderx2
Drives: 2014 FR-S
I would take it back now, find the time even. Once you go on your trip you wont be able to take it back without having to pay anything.
I'm not sure when you got the alignment but if its been a couple days already you may not even be able to take it back to have them correct it for free. They may claim you got into a pot hole or something.
KnightRyderx2 is offline   Reply With Quote
Old 03-21-2017, 02:23 AM   #11
Jonathan Le
Drives: Scion FR-S
I have a question, I just got alignment recently and my front camber left is 1.5 and right is 1.8 does .3 make a big difference? Should I just leave it alone?
Jonathan Le is offline   Reply With Quote
Old 03-22-2017, 07:07 PM   #12
wheelhaus
wheelhaus's Avatar
Not really, not enough to worry about. If you were tracking a lot or OCD I'd say get it closer to ideal, but not for a daily driver.
wheelhaus is offline   Reply With Quote
Alignment of steering wheel changes.... DrDuquette Issues | Warranty | Recalls / TSB 7 09-14-2015 11:51 AM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 12:15 AM
Steering wheel question buckseventysix Cosmetic Modification (Interior/Exterior/Lighting) 2 05-08-2015 10:40 PM
Steering Wheel Adapter Hub Question Bach415 Cosmetic Modification (Interior/Exterior/Lighting) 4 09-19-2014 05:40 PM
Steering wheel removal question. Dustin Cosmetic Modification (Interior/Exterior/Lighting) 13 03-20-2014 01:32 PM
